Results 1 to 4 of 4
Thread: 2000 silverado 2500 no brake lights
    Nov 2011
    2
    I have a 2000 silverado k2500 with the 7.4 liter and the old body style like the 98 or 99. My brake lights just stopped working. The third light, signals, and flashers are all fine. Twice ive fixed it (though im not sure how) and both times the next morning they wont work again. Replaced pedal switch and signal switch already and im getting power to my relay. I know the relay is good but somewhere after that im losing power. When I replaced the signal switch last night they worked fine. I walked away from the truck for a minute came back and they had stopped again. Im not even getting power to the plug next to the frame in the back.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,494
    Blog Entries
    2
    Check connection at third light.. does park lights work?
    Nov 2011
    2
    parking light work fine and as far as the third light it works fine also but do u mean the connection where the bulb plugs or at the pedal switch. I know very little about this. what i have figured out is what ive read from other threads on this site or just from messing with things myself which scares me cause knowing my luck ill end up screwing something else up when i play with wires.
    Dec 2007
    1,645
    May not be of much help to you but I remember reading something about a circuit board in the area of the spare wheel that can give trouble. Maybe check if you have that. If so check the connectors to it and maybe even consider replacing the board.
    Good luck.
  1. 2000 K3500 with no brake lights
    By JADennis in forum GMC Truck Forum
    Last Post: 06-11-2011, 05:10 AM
  2. Front parking lights 2000 Silverado
    By gonmoises in forum Chevy Truck Forum
    Last Post: 03-22-2011, 06:49 PM
  3. 1996 silverado no brake lights
    By 99 454 in forum Chevy Truck Forum
    Last Post: 07-09-2010, 07:05 PM
  4. 2000 gmc sierra Brake lights stay on ( Tail lights!!!! )
    By 2000GMC in forum GMC Truck Forum
    Last Post: 03-02-2010, 10:37 AM
  5. 2000 Tahoe Z71 ('99 body style). no brake lights
    By Zoomy in forum Chevy Truck Forum
    Last Post: 05-11-2008, 11:56 AM
