Results 1 to 8 of 8
Thread: 1987 Chevy C-10
    Dec 2011
    3
    1987 Chevy C-10
    I have a 1987 C-10 with the TBI 4.3V6. It does start will run when I'm giving it gas but won't idle. In addition while running if I turn on the lights it will die out. What could cause this problem?
    MikeG's Avatar
    Feb 2011
    Richland, Wa
    2,195
    Blog Entries
    1
    Sounds like a drain in the electrical system. Might want to look into getting a bigger (for lack of better words) alternator.
    '96 K1500 Ext. Cab Z71, 5.7L, Spectre Air Intake, 4L60E, 201K+, 13/18mpg
    My other car is Aircooled
    '69 Patina (0\_!_/0)
    Mar 2008
    N.Y.
    10,826
    Blog Entries
    1
    put a charger on it and see if it stays running
    Dec 2011
    3
    Already have new battery and alternator. It even does this when on jumper cables. Any other suggestions?
    Dec 2007
    1,645
    Could be a bad/dirty idle air control valve (IAC) or bad throttle position sensor (TPS) or bad/leaking EGR valve. Maybe check for trouble codes as a first step (can do this with a paperclip).
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,466
    Blog Entries
    2
    Does it start back up without boosting when it quits?
  7. #7
    Jan 2010
    Iowa
    1,746
    Quote Originally Posted by Case 7230 View Post
    do what he said.. sounds like a vac leak bringing the rpm down too far to maintain the load on the alternator.. IAC/EGR cuod cause that.. bad or dead spot in your TPS.. might even be a temp sensor for the computer reading that its really cold even after its warmed up and flooding it.............
  8. #8
    Mar 2008
    N.Y.
    10,826
    Blog Entries
    1
    when you changed the alternator...did you check all the driven parts to make sure they turn freely?
  1. 1987 chevy v30 4wd tbi
    By duners in forum Chevy Truck Forum
    Last Post: 11-16-2009, 12:39 PM
  2. 1987 Chevy Silverado 350 tbi
    By JayDukes in forum Chevy Truck Forum
    Last Post: 01-15-2009, 03:04 PM
  3. 1987 Chevy 2x4 into a 4x4??
    By frese9 in forum Chevy Truck Forum
    Last Post: 02-18-2008, 05:20 PM
  4. 1987 Chevy S/w/b
    By FIRE6 in forum Truck Classifieds
    Last Post: 01-09-2008, 07:52 AM
  5. 5.3 in 1987 chevy
    By ace in forum Chevy Truck Forum
    Last Post: 10-26-2007, 08:39 AM
