Results 1 to 2 of 2
Thread: 94 chevy z71 door lock
    Dec 2011
    1
    The driver side door of my 94 chevy 1500 won't lock. originally the door would open and close but you can lock the door with the key, manually on the inside or with the power lock. I took off the panel and tried to find out what was wrong. You can lock and unlock it when the module is loose but when you hook it back up it won't move. So i but it back together and now when you shut the door it automatically locks. So now i have to get in on the passenger side to open the door. Any ideas on what might be wrong? thanks in advance
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,374
    Blog Entries
    2
    You are saying when you take module loose ... you can take key lock ..unlock.? But with module connected..can not ?
    Now when module re connected locks door automatically?
    Sounds like module stuck in lock mode. Staying in this position would not let you lock with key.
    Might clean ..or replace it.
    What i,am thinking ............... Maybe someone else has their take on it .
  1. Van door lock cylinder pushed in
    By kirbymurphy in forum Chevy Truck Forum
    Last Post: 06-28-2011, 09:28 AM
  2. Pass. Door won't lock automatically.
    By Mikes96Z71 in forum Chevy Truck Forum
    Last Post: 01-21-2009, 03:11 PM
  3. Manual door lock question
    By goatman in forum Chevy Truck Forum
    Last Post: 06-11-2008, 10:17 AM
  4. Where Is The Door Lock Code
    By Lukka in forum Ford Truck Forum
    Last Post: 05-15-2007, 05:45 PM
  5. 93 PU door lock
    By Billy in forum Toyota Truck Forum
    Last Post: 11-29-2006, 05:14 PM
