Results 1 to 8 of 8
Thread: 1997 chevy truck code p0430 help
    Sep 2010
    Michigan
    56
    OK guys,
    After fixing my engine problem, now I have a new code-P0430- the clogged cats code. I have replaced all 3 O2 sensors with Bosch premiums and the truck loses power above 3000 rpm, so I'm guessing the cats(2) are clogged. Can I somehow clean them? Anyone have any luck doing that? I have seen some stuff that claims to clean them but I'm skeptical. Please advise.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    Sure must be some mean stuff. You are going to change probably anyways ..dropem see how truck runs .
    Just a thought ..
    Sep 2010
    Michigan
    56
    I think I drove too long with the bad CTS sensor, and the truck was always in warm-up mode, thus the clogged cats. I'm hoping there's a simple and good way to clean them, if anyone has suggestions I'm all ears.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    If it is the cats.. notta what would you pour in tank that would clean them ...but not mess all other components up.
    Besides it would burn up /dissipated before it got to the cat.. what do you think?
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    Tell you how to check the cats... before cats will be a whole lot hotter.. than after.
    After truck cools ..crank ..put hand before.. and one after ..should get same temp.
    Not too long gets hot quick.
    Or if you had a temp gun... I have seen a clogged cat get cherry red ..seen grass catch fire under it. ..wild.
    Sep 2010
    Michigan
    56
    Will try tomorrow chase-thanks a million. Will report back my findings and lean on you some more. Chase you must have a **** of a time carrying all that knowledge around with you
  7. #7
    Sep 2010
    Michigan
    56
    I tried the hand trick and there is very little difference in temp from before and after the cats. I cleared the code and drove if for a couple days with no issues, and going down the road today the ses light came back on with the same code. I think I am going to check voltage at bank 2 O2 sensor-
    Chase can you explain how to do this in simple terms? I have a good meter-just need some easy to understand instructions how to check. I never got this code until after replacing the oxygen sensors, so I'm thinking maybe the new sensor isn't reading right?
  8. #8
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    02,s working right. But to check have to have a scanner to read live data.
    You would ..get a code for 02,s if any problem.
    When you scan if... 02,s reading should change alot and quick.
    I wouls say ... cts dumping fuel in mess cat up.
    Will think some more ... but rear 02 is working reading cat is below threshold .
    Tell by my lazy typeing .. i,am slap dab tired .. done 2 metal roofs .. I know who cares lol
  1. 97 Chevy K1500 5.7 P0430
    By sindelic in forum Chevy Truck Forum
    Last Post: 10-18-2011, 04:50 PM
  2. Code P0430
    By Pat in Wa in forum GMC Truck Forum
    Last Post: 09-20-2011, 07:03 PM
  3. 1997 Sierra - P1345 Code
    By livestronggmc in forum Chevy Truck Forum
    Last Post: 04-18-2011, 11:04 AM
  4. 98 Chevy w 5.7 - Code P0430
    By JW-MX63 in forum Chevy Truck Forum
    Last Post: 02-23-2011, 10:57 AM
  5. 1997 Chevy K3500 T-Code & Vibration
    By NonGoggleGuy in forum Chevy Truck Forum
    Last Post: 03-12-2009, 04:00 AM
