Results 1 to 5 of 5
Thread: 02 chevy cold start rough idle
    Feb 2012
    3
    i have a 2002 chevy silverado 4wd 5.3 v8 with 143,000 miles on cold start the rpms ramp up to 200 for about 30 secs and drop to around 500 and barely stays running. after warms up runs fine, a local mechanic changed 02 sensors all 4, plugs, wire, cleaned injectors and throttle body. i changed tps sensor and ran fuel injector cleaner thru tank. i have codes of too lean bank 1 and 2 random cylinder misfire, and idle air excessive. any help would be appreciated
    Mar 2008
    N.Y.
    10,841
    Blog Entries
    1
    what is the reading on the scanner for the ecm temp sensor?
    Feb 2012
    3
    I don't know will have to check
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    Your getting to much un metered air in ..check for vacuum leaks at throttle body..air filter system...to throttle body
    Make sure it is all sealed tight...pcv valve... check all hoses...check the idle air control valve.
    Also clean the maf sensor.
    Feb 2012
    3
    Ok will check it out
  1. Rough Idle At Start Up!
    By musickerns in forum GMC Truck Forum
    Last Post: 01-22-2012, 01:05 PM
  2. 97 K-3500 w/454 rough start at times, then poof, fast idle on start
    By ScottinMaine in forum Chevy Truck Forum
    Last Post: 04-20-2011, 06:49 PM
  3. 2002 Silverado Z71 5.3L - Rough Idle and RPM Surge when cold
    By Chris.Thiel in forum Chevy Truck Forum
    Last Post: 03-24-2011, 01:11 PM
  4. Runs rough on a cold start
    By huntintruck95 in forum Chevy Truck Forum
    Last Post: 01-13-2011, 09:34 PM
  5. cold weather rough idle
    By 01chevsilv in forum Chevy Truck Forum
    Last Post: 12-07-2005, 05:07 PM
