Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 6.6 Duramax sudden power loss
    Feb 2012
    Indiana
    14
    My 05 Chevy duramax was running fine up I-75 until I took an exit ramp to get some fuel. When I got to the bottom of the ramp and I started to go again, the engine had lost almost all power and sounded like a 4-cyl with bad preignition. It would barely make 10 mph towing my camper trailer. I changed the fuel filter right away (I carry a spare), purged the air out of it and there was no improvement in the engine power. Is this one of those things that a dealer has to reset or is it something more serious?
    chevychase's Avatar
    Oct 2010
    truck forum .org
    19,690
    Blog Entries
    2
    Not much on diesels..do you have a service light? Did temp hand go to hot?
    Feb 2012
    Indiana
    14
    Quote Originally Posted by chevychase View Post
    Engine temp runs at the normal 190. Service engine light has been on all day. Probably not a good sign, but engine light is usually emissions related. Could that cause a shut-down?
    Full Member 98chevyz71's Avatar
    Dec 2011
    minnesota
    35
    by chance is it blowing white smoke? if so it could be turbo or injector pump issuses have cel checked and go from there http://www.justanswer.com/chevy/5mkb...ack-power.html
    Feb 2012
    Indiana
    14
    Quote Originally Posted by 98chevyz71 View Post
    by chance is it blowing white smoke? if so it could be turbo or injector pump issuses have cel checked and go from there Chevrolet Silverado 3500 2007 6.6 duramax has lack of power - JustAnswer
    The problem was a defective fuel injector control module. Total cost for diagnosis and replacement is just over $2 grand. Seems like something that costs that much would be bullet proof. Thanks for the replies.
    Mar 2008
    N.Y.
    9,911
    did the dealer fix it?...there are a lot of unwritten waurentees on the diesel systems
  7. #7
    Feb 2012
    Indiana
    14
    Quote Originally Posted by leolkfrm View Post
    I had a freightliner truck shop work on it. I will check and see if Chevy wants to make good on it. Thanks for the suggestion.
  8. #8
    Newbie
    Oct 2014
    2
    2008 6.6 L duramax, loss of power going uphill..pulling 5th wheel took to dealer changed fuel line, fuel filter and cleaned injectors. drove 85 miles and had same problem codes p0087,p2363,p0234.now they say may be turbo.. Takes to other mechanics and it runs great when not pulling 5th wheel so shouldn't be turbo? Don,t know what to do now. Still need help with this. George
  9. #9
    chevychase's Avatar
    Oct 2010
    truck forum .org
    19,690
    Blog Entries
    2
    Quote Originally Posted by geoturn View Post
    2008 6.6 L duramax, loss of power going uphill..pulling 5th wheel took to dealer changed fuel line, fuel filter and cleaned injectors. drove 85 miles and had same problem codes p0087,p2363,p0234.now they say may be turbo.. Takes to other mechanics and it runs great when not pulling 5th wheel so shouldn't be turbo? Don,t know what to do now. George
    you have some fuel lines/rubber collapsing will get poo87..with other codes sometimes the codes you post..but can get others. There is a technical service bulletin on this.
  10. #10
    chevychase's Avatar
    Oct 2010
    truck forum .org
    19,690
    Blog Entries
    2
    Google this will find your problem GM BULLETIN #PIP4526
  1. Loss of power when accelerating
    By chevyrunsdeep in forum Chevy Truck Forum
    Last Post: 11-01-2011, 03:51 PM
  2. loss of power
    By gaftop1 in forum Chevy Truck Forum
    Last Post: 02-02-2010, 08:52 AM
  3. loss of power
    By Butch Jones in forum Chevy Truck Forum
    Last Post: 07-01-2009, 11:52 PM
  4. Sudden loss of power
    By RangerJ in forum Ford Truck Forum
    Last Post: 03-01-2009, 03:45 PM
  5. 96 GMC Suburban loss of power.
    By Steven6456 in forum GMC Truck Forum
    Last Post: 01-15-2006, 09:06 AM
Tags for this Thread
