Old 03-17-2005, 11:31 AM   #1
Myles is on a distinguished road
99 Suburban Idle Problem
I have a 99 Suburban with a 454 that has a rough idle problem. It is worse sometimes than others. It runs fine above idle. The following items have been
replaced: fuel injectors, pressure regulator, plugs, wires, cap, rotor, intake gasket, oxygen sensors and the throttle position sensor. Does anyone have any ideas? I have been to 2 different dealers and have had no luck.
Thanks
Myles is offline   Reply With Quote
Old 08-02-2005, 05:16 PM   #2
Skyjockey is on a distinguished road
Run a compression check. I have a 454 in my motorhome and it had the same problem. Seemed like it ran great at rpm's above an idle and it turned out it had a bad exhaust valve in the number 2 hole. Valve guide was worn bad enough that it seemed to settle out above idle, but idled rough and was worse in the winter.
Skyjockey is offline   Reply With Quote
Old 08-03-2005, 10:52 AM   #3
Ford4x4Chik27's Avatar
How bout the fuel filter and pump?
Old 08-05-2005, 10:24 PM   #4
72'CaminoKid's Avatar
Smile 99 suburabn problem, possible solution
Hey, i have the smae car, excpet a 350, my dad has a 96 silverado, and we've recently been having similar problems, and we also replaced a lot of the same things you did, with no success...... today we cracked the case, it turned out to be that the cat convert. was clogged and no good. the way to test that, dependent on your capabailities, equipment, and exhaust setup, would be, if possible cut off the exhaust right before the cat's (like a few inches), and make sure there is a reasonable gap between the pipe comming out of the manifold and the rest of the exhaust (so that the majority of the exhaust isnt still goin through the cat). i'm assuming you have true duals back to the muffler, or even all the way out if you dont have stock exhaust, so you'll have to do this twice. after completing this, run your truck for a few minutes, driving it around, and see if the problem gets better ( obviously it will be VERY loud) if that solves the problem, just get your cat's replaced. you may want to weld back or clamp your pipes back together until you have the cat's replaced. also note, when cutting the pipes, dont use a torch or plasma cutter, (throws too much spark and molten metal to be near all that oil and gas) use a cutting wheel. if you cant do this, just completely unbolt the exhaust from both side of the block, make sure to pull out the donought gaskets, and try the same test...... this would be my best guess at the problem. since you say it mainly does it at idle, it could aslo be the ignition coils...... let me know if either of these solutions help, if ya need more detail, let me
problem with the Door open light BTAY Ford Truck Forum 4 03-30-2006 10:27 AM
Diesel problem jgn Dodge Truck Forum 2 06-01-2005 05:22 PM
fueling problem Bob k Ford Truck Forum 1 04-14-2005 04:02 AM
Biggest tires on a stock 93 Suburban 93 Burbon Chevy Truck Forum 2 03-20-2005 09:35 AM
Problem starting Keith23 Chevy Truck Forum 3 03-10-2005 09:43 PM
