Results 1 to 6 of 6
Thread: 2004 Chevy Silverado 2 Wheel Drive 4.3 Ltr
    Newbie
    Aug 2012
    3
    Hello all, I have a 2004 Silverado 4.3 Liter 5 Speed. 119,000. Won't start, can pull all 6 Spark plugs and with a remote start switch will turn over and Orange Spark on all 6, So far replaced Fuel Pump, Plugs, Wires, Cap, Rotor, Crank Shaft Sensor, Pulled and cleaned all injectors, Changed Oil. Any suggestions, Getting quite expensive changing every thing. Any and all Advice would be helpful.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,441
    Blog Entries
    2
    Need to check fuel pressure . Also can you hear fuel pump run when key is turned to on?Crank sensor would be a spark problem
    And others you changed seems your is fuel related.
    Welcome to the forum boozoh.
    Oh pressure should be at least 58 psi with key on ..and hold this.
    Newbie
    Aug 2012
    3
    Fuel Pressuure stay's around 62lbs. Even when cranking. Like my previous post, brought up too top dead center everything right on there. I can get a little back-fire when I take out the Fuel Pump Relay and pour a little bit gas right in.
    Moderator
    Jul 2011
    Central Oklahoma
    5,337
    Cam sensor? If its getting spark last thing check is fuel but you got good pressure there, could it be the something wrong in the fuel system like the injectors or something, if its a easy job might pull valve covers spin it over make sure they are all working like it should, when it back fires its it out the intake or exhaust?
    1994 white ext cab chevy silverado 5.7 rolling 230k miles
    stock with air filter lid flipped,
    open flowing exhaust to a 40 series flowmaster dumped.
    God Bless America, Support our Troops!
    Newbie
    Aug 2012
    3
    took pleinum off and run a volt test on injectors, all are working, could it be in the injector harness, this is not like the spider one's I'm used too. It seems you have to replace the wire assembly's one at a time. Even tried towing the truck and popping the clutch, just like no gas.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,441
    Blog Entries
    2
    What you need to do . Give it a bigger drink of fuel. Because your going in the air intake .take more to prime .
    See if it fires till fuel burned. If it does then has to be something not firing injectors. Check with a test light ..i think pink wire to each injector for pulse.
    Check the grounds. These work off ground signal from ecm. Check injector fuses should be two.
  1. Chevy 350 3/4 ton two wheel drive
    By Gary C in forum Chevy Truck Forum
    Last Post: 08-05-2012, 07:17 PM
  2. 2003 Silverado 1500 4-Wheel Drive Issue
    By keepincalm in forum Chevy Truck Forum
    Last Post: 07-16-2012, 07:25 AM
  3. 1986 chevy 2 wheel drive rear axel drive tire?
    By Lucky1DDH in forum Chevy Truck Forum
    Last Post: 12-14-2011, 07:33 PM
  4. 79 chevy k10 4 wheel drive
    By jerry w in forum Chevy Truck Forum
    Last Post: 10-15-2011, 08:23 PM
  5. 2004 Silverado wheel sizes
    By rdhack in forum Chevy Truck Forum
    Last Post: 07-23-2011, 09:27 AM
