Results 1 to 9 of 9
Thread: 86 chevy 350 not getting fuel
    Newbie
    Sep 2012
    1
    I replaced the fuel pump, filter and fuel line, i pour gas in to carburetor and it turns over and runs briefly, however as soon as the gas in the carburetor is gone it shuts off and won't run the fuel filter doesn't have so much as a drop of gas in it...any ideas as to why? have already tried both fuel tanks.
    Jan 2012
    South MS
    462
    sock/fuel pick up in the tank or the rubber lines connecting the metal line.
    Is there a fuel filter under the cab?
    DS
    Moderator
    Jul 2011
    Central Oklahoma
    5,332
    If he has a carb it will be on the carb don't think they put filters on the frame but may have in that year, are you sure pump is pumping, is it the pump in the motor or one in the fuel tank.?
    1994 white ext cab chevy silverado 5.7 rolling 230k miles
    stock with air filter lid flipped,
    open flowing exhaust to a 40 series flowmaster dumped.
    God Bless America, Support our Troops!
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,392
    Blog Entries
    2
    Why did you replace pump? for the symptom your having?
    Try this take filter loose turn engine see if fuel comes out.
    Moderator
    Jul 2011
    Central Oklahoma
    5,332
    Oh just thought of this the carb filters go in one way they have a flap valve keeps fuel at the carb to start easier is it in the right way, iirc the flap valve goes in first against the carb.
    Jan 2012
    South MS
    462
    It is dual tanks? Same on each tank? The selector switch may be a issue. Its common.
    DS
  7. #7
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    bypass the selector switch and try just one tank.
  8. #8
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,392
    Blog Entries
    2
    Quote Originally Posted by gpmorgan View Post
    I betcha this will be the bingo/right?
  9. #9
    Mar 2008
    N.Y.
    10,788
    Blog Entries
    1
    Quote Originally Posted by hllywd322 View Post
    you are describing an old the block pump carb set up, is this what ou have? if so look for bad spot in the fuel line farther back it may be sucking air
  1. 1987 Chevy No Fuel
    By dcfd470 in forum Chevy Truck Forum
    Last Post: 02-07-2015, 12:26 PM
  2. 1987 Chevy No Fuel
    Last Post: 05-06-2011, 06:19 PM
  3. 84 Chevy C20 Fuel Pump
    By 1984ChevyC20 in forum Chevy Truck Forum
    Last Post: 04-28-2009, 07:35 PM
  4. Fuel Mileage on 06 Chevy
    By BillSimm in forum Chevy Truck Forum
    Last Post: 03-06-2008, 12:01 PM
  5. 93 Chevy 454 no fire or fuel
    By Jonc in forum Chevy Truck Forum
    Last Post: 10-11-2006, 08:55 AM
Tags for this Thread
