Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: 2000 chevy silverado 5.3 starts And dies
    Senior Member asifford5's Avatar
    Dec 2010
    Woodland CA
    67
    The truck starts starts and then dies within 30 seconds after a few starts it won't start up at all may be computer related? I have no idea where to start
    1990 GMC K1500 4x4 SB 350 (daily driver)
    1988 Chevy V-20 Scottsdale Suburban 4x4 SB 350 (project)
    Moderator
    Jul 2011
    Central Oklahoma
    5,329
    Need to test fuel pressure should be running around 60psi.
    1994 white ext cab chevy silverado 5.7 rolling 230k miles
    stock with air filter lid flipped,
    open flowing exhaust to a 40 series flowmaster dumped.
    God Bless America, Support our Troops!
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,367
    Blog Entries
    2
    Also should hold the pressure..can check with key on..also need to find out if fuel .or spark that it lacks on a no start.
    If a service light on scan for a code ..if light is on ..maybe crank sensor..a symptom of a crank sensor.
    But do not replace till you check for lack of spark and fuel..and scan.
    Will have a valve on fuel supply line at intake to check pressure..might rent a gauge at auto parts.
    If it is senor related should have a service light.
    Dec 2010
    Woodland CA
    67
    Not sure if it matters but its got a 4.8 in it not the 5.3
    Dec 2010
    Woodland CA
    67
    It has 3 codes
    P1122P1637
    P0122
    Senior Member Sodell's Avatar
    Oct 2011
    NW Arkansas
    963
    P1122 TP Sensor Circuit Intermittent Low Voltage
    P1637 Generator L-Terminal Circuit
    P0122 is your TPS, that is where I would start after you check the fuel pressure
  7. #7
    Mar 2008
    N.Y.
    10,761
    Blog Entries
    1
    ecm temp switch...try fuel down the throttle body, if it starts feed fuel and see if it will continue to run
  8. #8
    Dec 2010
    Woodland CA
    67
    It will not run any longer then usual with starting fluid into the throttle body
  9. #9
    Dec 2010
    Woodland CA
    67
    We hooked up the fuel pressure Guage and turned the key and had 35 psi then started it and the Guage jumped between 30 and 35 psi then it died with 0 psi and turned key off and back on and did not build up any pressure. How much pressure does the 4.8 need? Why would it just stop pumping?
  10. #10
    Mar 2008
    N.Y.
    10,761
    Blog Entries
    1
    do not use starting fluid...not good for the engine! when dumping gas in the throttle body and it will not continue to run it sounds like a spark problem...dumping gas in would make it a fuel problem...check spark at teh plugs when it wont start
  1. 2000 Chevy Silverado w/ Mysterious Noise
    By Boomschoom in forum Chevy Truck Forum
    Last Post: 03-29-2009, 07:08 AM
  2. 2000 Chevy Silverado 1500
    By Fatcat in forum Chevy Truck Forum
    Last Post: 06-23-2008, 08:10 PM
  3. First Post Here, 2000 Chevy Silverado PROBLEMS!
    By sprky_02 in forum Chevy Truck Forum
    Last Post: 01-18-2007, 05:44 PM
  4. 2001 Chevy Silverado Z-71 Starting Problem
    By a5150joseph in forum Chevy Truck Forum
    Last Post: 12-03-2006, 08:11 PM
  5. Need help with hesitation with my 2000 Chevy Silverado
    By RSailer in forum Chevy Truck Forum
    Last Post: 05-08-2006, 05:19 PM
