Old 10-05-2005, 08:17 PM   #1
92Jag's Avatar
92Jag is on a distinguished road
Anti freeze leak none on ground
I filled up the anti freeze in my truck cause it was bone dry then 3 days later it was bone dry again what going on there is no leakage on the grond what should I do?
92Jag is offline   Reply With Quote
Old 10-06-2005, 10:15 AM   #2
Moostang's Avatar
Check your oil to see if it looks normal. I think it starts to look milky
Also, take a quick smell of your exhaust to see if it smells sweet.
Anothing thing, is make sure your overflow doesn't have a hole in it and has the cap on. If you are losing water through there, it would most likely happen when you are driving which means you won't see it, although when you stop after a drive you may see it still leaking.
MEOW!!
Old 10-06-2005, 11:02 PM   #3
chevyguy's Avatar
If it aint leaking it it is either in the oil pan or going out the exhaust. Either way bad news.
Old 10-07-2005, 02:54 PM   #4
92Jag's Avatar
Yea its bad news what can I do to fix it? I am prety sure it's going out the exhoust cause the pipe smells sweet. I am not sure if it's in the oil or not?
Old 10-07-2005, 06:28 PM   #5
Moostang's Avatar
Well check the oil too... if its in either, it am guessing you are going to find your leak in your head gasket (take in mind I am a ford person so those are the engines I know). And depending on the damage and where the leak is, it could be as be just changing a head gasket, or a possible full rebuild.
MEOW!!
Old 10-07-2005, 10:25 PM   #6
chevyguy's Avatar
If it is in the oil or going out the exhaust more hopefully just a head gasket, Could easily be more though to include a cracked head, or cracked block. Either way you have to tear it down to find out. If the oil looks milky stop driving it until it is fixed. I dont remember what year you said this was but if it is a vortec you might be in luck ( whoever was the genius that created the plastic upper plenum needs to be shot) but the upper plenum is problemmatic for coolant leaks leaking into the motor, Might be a simple gasket.
Old 10-09-2005, 10:27 PM   #7
darkpony02 is on a distinguished road
Check your passenger side floor board under the mat, if its wet you've got a leaking heater core possibly.If the other signs arent there this would be one of the reasons coolant disappears without a trace.
darkpony02 is offline   Reply With Quote
Old 10-09-2005, 11:12 PM   #8
chevyguy's Avatar
Sweet exhaust was alreday mentioned. Checking the floor board at this point is nothing more than a way to find loose change.
Old 10-10-2005, 05:54 AM   #9
92Jag's Avatar
Its a 78' Chevy Scottsdale. What gaskets sould I start replacing first?
Old 10-10-2005, 09:55 AM   #10
chevyguy's Avatar
Try to identify the problem before you just start replacing stuff. Was there water in the oil, or oil in the water, or is it just sweet exhaust?
