Old 10-10-2005, 11:39 AM   #11
92Jag's Avatar
92Jag is on a distinguished road
Just Sweet Exhaust oil and water looked fine.
92Jag is offline   Reply With Quote
Old 10-10-2005, 01:32 PM   #12
chevyguy's Avatar
Time to pull the heads off and check the head gaskets. If no blown section found then have the heads magnafluxed. Should get a good idea of which head is the problem when you pull the heads off and inspect the cylinders
Old 10-11-2005, 12:48 PM   #13
92Jag's Avatar
Ok how do I go about pulling the heads I have never watched someone do it or have the slighits clue how you will have to walk me through this one. I'll try to find something online on how to do it. How long will it take?
Old 10-11-2005, 12:59 PM   #14
chevyguy's Avatar
Gp to your local parts store and purchase a chilton manual. It will walk you thru the whole process. Best way if you have never done it before.
Old 10-12-2005, 07:29 AM   #15
Moostang's Avatar
Great suggestion to get the Chilton book for your truck. Before you start taking your truck apart, make sure you have the proper tools (torque wrench is on the top of the list) and a ride to the parts store once you pull that head you are going to need head gaskets, intake gaskets (remember I am a ford person so that is what I am thinking of) and sealant, even if you don't find a problem, don't reuse the current gasket.
The best thing to have is a buddy experienced in that.
Also, I don't know if the manual tells you, but if you refilled your radiator, drain it first, then change your oil when are done. Oh, also instead of using a spray on gasket remover I prefer to use a razor blade to scape off any sealant stuck to the block, last thing I want is that chemical anywhere in my block.
Good Luck
MEOW!!
Old 10-12-2005, 06:24 PM   #16
chevyguy's Avatar
^^ thats good advice. i also use the gold spray on gasket sealer for head gaskets. Seems to work out well. this can be done without pulling the intake, But it is a PIA. Especielly when you truck is as simple as your is without a whole lot of electrinics, i suggest pulling the intake as well. If you do decide to do the work yourself let me know, i have a few tips that might help you out on reassembly. Good luck and drop in and let us know what you decide.
Old 10-12-2005, 08:20 PM   #17
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
i agree, about pullin the heads without pullin the intake.... i had my engin over heat and sieze a valve which a piston slapped. we pulled the head without pullin the intake, and it was a PAIN
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 10-12-2005, 08:39 PM   #18
chevyguy's Avatar
See, I do know somethin.He he he heh hehehehehehehehe
Old 10-12-2005, 08:44 PM   #19
Moostang's Avatar
Doesn't the intake bolt to the heads? Of course I am probably wrong on Chev's
MEOW!!
Old 10-12-2005, 09:30 PM   #20
chevyguy's Avatar
No you are correct, but if you only need to pull one head, you remove the intake bolts on that side and pull all the head bolts. This is really usable on diesels where alot of injector components and such use the intake manifold . They can be really intimidating to a novice so it is easier to leave the intake in place. Not so much on the older chevy gas motors though. .. Oh i really dig the goofy goat pic too.
