Old 10-23-2005, 06:51 PM   #1
98Z71 is on a distinguished road
bad shaking when driving
hello guys i just put 33X9.50x15's on my 98 z71 and i had it aligned afterward i was driving and i hit a bump and the hole truck started to shake side to side really bad it has been doing it ever since i had it aligned i dont think that had anything to do it it. could it be the ball joints? any help would really help thanks guys
98Z71 is offline   Reply With Quote
Old 10-23-2005, 06:58 PM   #2
splinter is on a distinguished road
DEATH WOBBLE!!!!!!!!
Start with your track bar, then go to your steering linkages. Sway bar probably won't do it to you, but check all of your bushings while you're at it.
I had a Cherokee that did the same thing.
It's a coil sprung thing.
Ball joints, control arm bushings, anything could be causing this, and it is aggravating and sometimes expensive to fix. You wind up replacing things that you didn't need to replace until you finally replace what was wrong.
Good luck with it man,
Chris
It used to be a Jeep thing, you wouldn't understand.
splinter is offline   Reply With Quote
Old 10-23-2005, 08:50 PM   #3
Senior Member++
DodgeChick's Avatar
DodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really nice
Death wobble lol.....
You could check all those things but I usually like to look for the simple things first and rule them out before diving into expensive parts.
Maybe you lost a wheel weight....or you simply need another alignment and balance after that jar to line things up again. Id rule out the simple fixes first...if they dont do it then go checking the big things like Splinter listed.
Goodluck!
2002 Patriot Blue Ram 1500 4x4 in the process of some mods
*****Voted Best Truck on HGS*****
Silly boys!! Trucks are for girls!!!
"Grab Life By The Horns"
DodgeChick is offline   Reply With Quote
Old 10-24-2005, 08:28 AM   #4
390FE's Avatar
390FE will become famous soon enough
I was thinking weight too but you said it did it sence allignment. Did it shake when you drove it to get alligned(if you did drive it?)
Did a reputable shop do your allignment? Was it a spin balance or bubble balance? I am guessing spin but some shops still use the bubble balance. Spin balance is much better and if you can find a shop with the machine get them road force tested. You may have a bent rim if you bought the rims used. Are the tires you put on new or used? There are a lot of variables and even more when you get into used parts. But I'm sure you already know that.
I had an allignment done once on my focus. I payed the guy $50 and the steering wheel was not centered when done. Brough it to Ford a week later and paind them $70 for 4 wheel alignment to fix the bad alignment. Ford gives you those sheets of before and after and it was way off on the before printout.
390FE is offline   Reply With Quote
Old 10-24-2005, 09:28 AM   #5
chevyguy's Avatar
Sounds like you found so slop in the front end, now you just need to find it. Check all front end ball joints and bushings.
Old 10-24-2005, 03:58 PM   #6
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
i'm sure u may of done this already, but did u check to make sure there isn't a bubble/bulge in the tire that hit the hole?
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 10-24-2005, 04:10 PM   #7
chevyguy's Avatar
If it only does it sometimes, the tire issues are eliminated, but if it happens now everytime you brake, or accellerate than look for damage front end components
Old 10-24-2005, 08:24 PM   #8
ok i think i got it figured out i changed the pitman arm and the idler arm and bracket there was alot of play in the pitman arm but not anymore it dosent shake when you hit bumps anymore thank for all your help guys
Old 10-24-2005, 09:42 PM   #9
Senior Member++
DodgeChick's Avatar
Glad you got it figured out fairly easily!
Old 10-25-2005, 11:53 AM   #10
chevyguy's Avatar
Outstanding, Good job
Huron Daily Tribune - News - 08/15/2005 - Baker College adds truck driving school in Port Huron (Huron Daily Tribune) trucknews Truck News (headlines) 0 08-15-2005 11:30 AM
FedEx To Send Record 69 Drivers To National Truck Driving Championships (The Auto Channel) trucknews Truck News (headlines) 0 07-18-2005 11:30 AM
Land Rover to Open Third Driving School in North America (The Auto Channel) trucknews Truck News (headlines) 0 06-23-2005 03:30 PM
OFF-ROAD RUN: Advanced Driving School teaches students how to handle unexpected situations (Winston-Salem Journal via Yahoo! News) trucknews Truck News (headlines) 0 08-01-2004 03:30 AM
Arkansas Truck Driving Championship (The Searcy Daily Citizen) trucknews Truck News (headlines) 0 07-27-2004 07:30 PM
