Closed Thread Chevy Truck Forum - Chevrolet / Chevy trucks and their accessories forum.
Old 11-08-2005, 09:45 PM   #1
Robbman is on a distinguished road
90 C1500 engine problem...HELP!!!
Hey All, 1st timer here and I need some advice. I am having a clanging noise coming from the engine. Was on the interstate and heard a loud clanging, like something rattling around, then smoke poured from under the hood. When I looked, could not tell if it was water or oil. The truck still had power and still starts up but has that clanging noise. Before I look at getting a rebuilt engine, just trying to get some suggestions on other possibilities. By the way, when engine was examined, no sign of a rod through the block or the oil pan. Valve covers are in perfect shape. Someone told me that it could be a broken blade in the water pump flying around...is this possible or is there another suggestion? Thanks for any help you can give me.
Robbman is offline
Old 11-09-2005, 09:10 AM   #2
chevyguy's Avatar
Remove the belt and start it up briefly, If the noise is gone then it is in the water pump, If not then it is internal. I recommend checking the oil and other fluids first before starting it and making sure nothing is hanging around where it shouldnt b If it was your water pump, then you are probally real low on water. Should be an indicator. Hope this helps. Let me know what you find.
USMC 92-96 USCG 98 to present
chevyguy is offline
Old 11-10-2005, 07:24 PM   #3
Thanks Chevy
Hey Chevy...appreciate the advice. I will try that this weekend and see what we come up with. I will let you know how I make out.
Thanks again
Robbman is offline
Old 11-10-2005, 09:14 PM   #4
chevyguy's Avatar
O.K. I am interested to see what you find out.
chevyguy is offline
Old 11-14-2005, 04:14 AM   #5
Hey Chevy
Tried the Water pump thing yesterday. It was not the water pump. Got a loud tapping on the right side of the engine. Took the valve cover off and removed the push rods, alot of carbon build up on them, but they were not bent or broken. Pushin oil through fine. I am now assuming I have a valve knocking. I do not hear the clanging noise anymore and there is no more smoke coming from the engine. Lost no oil. Will a piston knock like that? Is there a way of checking the valves to see if it's them and also which one? And is there a way of checking the Pistons? Appreciate all your help.
Talk to ya later.
Robbman is offline
Old 11-14-2005, 04:22 AM   #6
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
Hook up a timing light. Use it on your lifters with the engine running and the valve covers off. If you have one not moving you will see it that way. Also check your baffles in the valve cover, if clanging is gone with valve cover off a baffle may have broken loose.
Kennyray is online now
Old 11-14-2005, 04:38 AM   #7
Hey Number
Thanks for the info. The noise continues when the valve cover is off. The Valves are moving up and down and the oil is flowing through the rods. I was wondering, what are the chances that the Knock sensor is bad? It is located on the same side as where the knocking is coming from. This is definitely a Knocking sound. The clanging sound is no longer happening.
Thanks for your help
Robbman is offline
Old 11-14-2005, 01:42 PM   #8
chevyguy's Avatar
Why do i keep thinking this sonds like a wrist pin? Use a long screwdriver as a stethascope (sorta) touch it to different parts on the motor with the engine running and touch your ear to the handle end, It will help you identify where the knocking is coming from. Sound travels better thru a solid than it does thru air so you should be able to identify the source of the knock
chevyguy is offline
Old 11-15-2005, 06:20 AM   #9
Hey Chevy
Okay I tried that and it is the loudest on the right side toward the front of the engine. Even took off the Valve cover and listened to each valve and and they all sounded the same. The Knocking was not coming from there. When I did it on the Intake Manifold, toward the front right, that is where it was the loudest. What is a wrist pin and how do I check that? i also heard that the Knock sensor could be bad or the Timing Chain gears could be messed up. Also someone said something about Spark ignition problem. Is that corrected by changing the plugs and the points?
Thanks again,
Robbman is offline
Old 11-16-2005, 09:42 AM   #10
chevyguy's Avatar
Its a 1990 it doesnt have points. It is an electronic advance computer controlled high energy ignition. Are you getting any truoble codes (check engine light) A knock sensor will set of the check engine light. If it is coming from the front try to listen at the timing chain cover. If it is a wrist pin the a complete rebuild is in order. Wrist pin is the pin that goes thru the piston
chevyguy is offline
Closed Thread
engine problem Bob k Chevy Truck Forum 8 10-04-2005 10:17 AM
02 S10 problem 84ranger Chevy Truck Forum 3 05-20-2005 08:28 PM
TRUCK PROBLEM...need advice animal GMC Truck Forum 3 05-05-2005 01:18 AM
89' 5.7L Engine Problem 189Flyer Chevy Truck Forum 0 02-22-2005 03:10 PM
engine problem joe rod Dodge Truck Forum 0 12-14-2004 03:46 PM
