Old 11-14-2005, 10:35 AM   #1
frednicholson is on a distinguished road
PROBLEM installing Stall Torque Converter
This is an 88 Chev. After installing a Stall Torque Converter (700R4 transmission 4L60), the converter locked up. We replaced the converter and the fatory said the original one checked out ok. If anyone has a solution or theory about why this converter is not working, please respond.
thanks....
frednicholson is offline   Reply With Quote
Old 11-14-2005, 09:34 PM   #2
Moderator
Locked up? Please describe more.
Old 11-14-2005, 10:18 PM   #3
chevyguy's Avatar
Need more info, Did it function for any period of time or did is seize when it was installed? Was the truck ever driven with this converter in it.
Old 11-15-2005, 05:26 PM   #4
hotrod69's Avatar
hotrod69 is on a distinguished road
It Might Be One Of The Solonoids For The Lockup Torkue Converter Is Bad Probably The Manuel Lockup Solonoid The Other Solonoid Only Locks It Up In Fouth Gear.
HOTROD
NOTHING LIKE DRIVING A CHEVY
hotrod69 is offline   Reply With Quote
Old 11-15-2005, 05:32 PM   #5
hotrod69's Avatar
Also Need More Info. Because The Manuel Lockup Only Works In Second Thru Fourth These Transmissions Are Very Particular On How They Are Installed And Tuned,they R Not Like A Th350 Or 400u Need A Pressure Gauge And A Working Knowlegde Of The Tranny If Not U May Have Damaged That Tranny Already.
HOTROD
Old 10-29-2007, 05:57 PM   #6
Performabuilt99 is on a distinguished road
you might have broken the pump when you installed the tranny.
Performabuilt99 is offline   Reply With Quote
Old 10-30-2007, 06:57 AM   #7
Moderator
being almost 2 years old, i hope they solved the problem by now.
Old 10-30-2007, 08:01 AM   #8
That transmission guy dug up every transmission related thread available, regardless of age.
Suprised he did not try to peddle his shops stuff in this one.
Was difficult to keep up with current threads.
Old 10-30-2007, 07:44 PM   #9
bkzues1 is on a distinguished road
is there a possiblity you butted the pump?when you insalled it was there any play between the converter and the flex plate there are differcines between 4l60e and 700r4 trans if you have the orignal converter check the bolt pattern depth betweenthe too
bkzues1 is offline   Reply With Quote
