| Junior Member Join Date: Nov 2005
| Want to lift my `03 1500HD 6" with 35" tires. Which lift is the best and why. Also do not want any white letter tires, any suggestions? how about tires with a little less aggressive tread design ? comments about alignment, spedo recalibrate, front shaft issues, kunckles vs ? . thanks for any info. |
| Go with a reputable company. i am not recommending any but you can look them up. What you buy is what you get. STAY AWAY FROM BODY LIFT, unless you want your truck looking goofy. As for tires i like Real agressive tires so I cant help much there, check with your local tire dealer. If you lift more than a couple inches get i kit with a front differential drop, or you need longer shafts that will only bind up anyway. Speedo recalibrate on you truck has to be done with a computer.
| Full Member Join Date: Nov 2004
| id go with pro comp their kits keep the front end width stock you have to use 8 inch wide rims to run 35's with the procomp kits go with the bfg all-terrains they are great tires |
| That tire and wheel combo will work with all lifts that drop the front diff. procomp, tough country,superlift, just to name a few. Do some internet shopping around, see what you can find
| best lift for an 05 z71 | 05z71crew | Chevy Truck Forum | 8 | 11-30-2006 08:39 PM |
| suspension lift | chevy kid | Chevy Truck Forum | 1 | 09-10-2005 09:30 PM |
| Suspension lift kits | RichardLGriffin | Ford Truck Forum | 5 | 09-06-2005 07:05 PM |
| Lift Truck Attachment safely handles rimmed drums. (ThomasNet) | trucknews | Truck News (headlines) | 0 | 05-13-2005 11:30 AM |
| Lift Truck Control offers voltage monitoring function. (ThomasNet) | trucknews | Truck News (headlines) | 0 | 11-08-2004 09:30 PM |
