| Junior Member Join Date: Aug 2005
| Blazer Transmission Folks, Needyour help. Does anyone have any information on possible transmission / transfer case issues with the 2002 Blazer. At 45,000 vehicle needs extensive repairs, and I feel GM should be footing some of the bill. Please responsd asap. mikerike |
| Full Member Join Date: Aug 2005
| hello my uncil had problems with the transmission and the engine the 4x4 drive shaft runs right threw the oil pan and if the eather of the two seals fail the oil pours out and your in big trouble. my advice fix the trans keep it untill the warrenty is about to expire then trade it.and always check oil level strange design |
| Umm 45000 on the clock, unless it had the extended warranty, it is out of warranty, If it was under warranty chevy would be footing the bill. need to know if the maintenace was kept up and what happened to the trans when it gave up? Is it lifted, owned by a kid? Used in the mud alot.
| Yes, you are right able being out of warranty. Maintainance was done on schedule. Owned by a young lady; not abused or misused ever. While diving at approximately 35 mph, 4 wheel drive lights started to go off and on. Loud clunk heard and immediately stopped to investigate. No external damage visual. When I went through the gear selection, realized only forward gearing was operative; no reverse. I serious feel there was a malfunction that occured in transfer case / transmission since the 4x4 selection lights were acting weird; as though the vehicle was shifting into 4 wheel drive on its own. P.S. I have had 5 GM products and never have been under the impression that trannies are good only for 45,000 - warranty or not Chevy should step up and do what's ethical. Is there any service bulletins that were put out to indicate possible issues with the 2002 Blazer?? Thank you in advance for any assistance that you can provide, mikerike |
| No service bulletin. I called my friend that works at the general motors and there is no service bulletin he knows about. Sounds like it was dropped into 4 wheel low while moving . It should be shift oin the fly, but not into low range. Either the actuator manfunctioned, or someone accidentally hit the 4 low button. These are my guesses. Sorry but your on your own as far as the repairs go. There is now way to prove it wasnt actually operator error. Sorry friend.
| Thanks I take the case to small claims court |
| Without evidence something actually malfunctioned and someone didnt accidentally hit the 4 low button at cruising speed,there is no use.
| Each state has its own unique Consumer codes. I think my states codes would provide some room for remedy Thanks for your correspondence and hope to hear from you in the future |
| hope this works out for ya, Good luck man.
| auto transmission won't shift and rpm& speed guages don't work | gmcer | GMC Truck Forum | 13 | 05-04-2006 08:27 AM |
| Transmission help | damarr30 | Dodge Truck Forum | 2 | 10-30-2005 12:09 AM |
| Transmission Help Needed | George911 | Ford Truck Forum | 7 | 08-02-2005 11:35 AM |
| QCTimes.Com: Top Jobs: CHEVY '95 S10 Blazer 4 Dr 4x4 (Quad-City Times) | trucknews | Truck News (headlines) | 0 | 05-29-2005 03:30 PM |
| 1999 Chevrolet Blazer S-10 4X4 review (Carsurvey.org) | trucknews | Truck News (headlines) | 0 | 01-02-2005 07:30 AM |
