Closed Thread Chevy Truck Forum - Chevrolet / Chevy trucks and their accessories forum.
Old 11-18-2005, 07:10 PM   #1
1987 throttle body fuel pump problem
I have a 1987 k10 4.3 v6 full size fuel injected truck. About two months ago I was coming to work in a heavy rain. When I got out of work that nite (i work 2nd shift) I could hear my fuel pump running. Well It started and when I went home it was still running 3 miniutes after I shut it off so I disconnected the battery. Next day I replaced the fuel pump relay on the firewall no difference. The fuel pump runs even with the relay disconnected! Well when everything dried out it went back to normal operation. The other nite it rained and it drained the battery. fuel pump running continuously. I figure the pump is energised and the relay makes the ground? Haynes manual is no help wiring dia does not even show a fuel pump. Were can I get a wiring diagram for my truck? Have any of you ever seen this before?
Fred
wojeepster is offline
Old 11-18-2005, 08:06 PM   #2
chevyguy's Avatar
The fuel pump relay is the control circuit. it is somehow closing the contacts when it gets wet. Try to pull the fuel pump relay next time it does this and see if it turns it off. This will help with diagnosis
chevyguy is offline
Old 11-19-2005, 06:40 PM   #3
even with the fuel pump relay disconnected the pump still runs.
Old 11-21-2005, 02:16 PM   #4
Does anyone know where I can obtain a wiring diagram for my truck? 1987 k10 4.3 v6 throttle body?
Old 11-21-2005, 09:22 PM   #5
chevyguy's Avatar
Chilton manual. Sounds like you are gonna need to take electrical readings(voltage and resistance) to find this one.
chevyguy is offline
Old 11-22-2005, 04:15 PM   #6
thanks, I will
Old 11-28-2005, 04:27 PM   #7
So a newer haynes manual had the throttle body wiring diagram power runs from relay to engine oil pressure switch and ecm. Since it continues to run with the relay removed I am fairly certain I have a problem with the oil pressure switch or the ecm itself. I will unplug the oil pressure switch the next time it happens. Maybe it is stuck in the on position? Once oil pressure is made is that where the fuel pump gets 12v from?
Old 11-29-2005, 04:34 PM   #8
splinter is on a distinguished road
Oil pressure shouldn't turn your pump on or off, because the pump runs when you turn your key to the on position without starting the engine, and there is no oil pressure then.
It used to be a Jeep thing, you wouldn't understand.
splinter is offline
Old 11-30-2005, 07:15 PM   #9
Well today I went out to my truck and hooked up the battery cable and fuel pump immediately started. I climbed under the truck and tapped on the oil switch and fuel pump stopped. I think it uses the relay to start initally and then as long as you have oil pressure the fuel pump runs. Oil switch sends info to ecu, ecu powers pump. thats my best guess anyway. I have a new switch ordered.
Old 12-01-2005, 02:26 PM   #10
Good call, I never thought of it that way.
Glad to see that you fingered it out!
splinter is offline
Closed Thread
chevy s10 fuel injector problem... rrodriguez190 Chevy Truck Forum 8 10-29-2005 11:23 PM
dead fuel pump walterv Dodge Truck Forum 8 10-28-2005 06:33 AM
Fuel Pump Problems p_kotenko Dodge Truck Forum 3 07-10-2005 06:45 AM
fuel pump sean Ford Truck Forum 3 10-27-2004 09:37 AM
