| Junior Member Join Date: Nov 2005
| I have searched all over the internet and can't find anything or anyone that has had this problem. Last night I got in the truck and turned on the heat one side is blasting out warm air the other side cold. Doesn't matter what position, floor, defost or out the air vent it stills just blows cold air. Help!! It is cold outside. It is a 2004 Silverado cab and half. Last edited by gizzmo; 11-22-2005 at 10:00 AM. |
| year make and model are gonna be needed to help out with diagnosis. Some heat units are vacuum controlled, others are electric. Depends on year
| Thanks, forgot that part!!! |
| Sounds like an air door is not opening. It shopuld be vacuum actuated on yours (Ithink) cant remember what year they switched over.
| i know up till 99 before they changed body/interior they were still vacuum. If it's any help
| Thanks you guys are great!!! I will give it a try. |
| Junior Member Join Date: Aug 2006
| I have the same problem but only intermittantly, if you figure it out let me know please? |
| Dealer solved the same problem for me. Reprogrammed the computer that controls the system.. per some gm bulletin. Problem solved. Also a 2004. |
| Junior Member Join Date: Nov 2006
| I also have the 2004 Silverado and had it back to the Dealer two times to be fixed.
__________________ frank |
| This is from the work order on my 04 Chev. silverado... "Scanned 2 codes in system D4707 & D1811 Refered to Bull. 06-01-38-003 Reprogramed HVAC. Still noticed acctuator failure after calibration. Replaced right temp. door acctuator and all working per design."
| dual exhaust on a 97 chevy truck? | hampton | Chevy Truck Forum | 11 | 07-24-2006 05:52 PM |
| Dual Exhaust questions | Beaver3000 | GMC Truck Forum | 19 | 01-05-2006 08:37 PM |
| universal joint on front drivers side wheel | ramdodge | Dodge Truck Forum | 3 | 07-16-2005 12:02 AM |
| A truck goes off the side of the road crashing into a semi (ABC 7 Chicago) | trucknews | Truck News (headlines) | 0 | 05-06-2005 11:30 PM |
| 4Sale: Dual Electric Fan 99-02 GM Trucks | cbx1980 | Chevy Truck Forum | 0 | 09-08-2004 09:43 AM |
