Old 11-22-2005, 08:21 AM   #1
slavio is on a distinguished road
PLZ HELP!!! 350 to 305 swap TBI not pulsating!!!
I have a 93 2500 4 X 4 truck with a plow on it..........it had a 350 in it and i pulled it out because it was really worn down with 370 000klms on it. i bought a crate engine 305 and put it in with everything hooked ready to go.
The engine turns over the fuel pump presurizes and there is fuel at the throttle body just before the two injectors. when it turns over there is no fuel spittin out of the two fuel injectors. when fuel from a bottle is thrown in the throttle body it starts for a second. ive come down to that there is no pulsating at the injectors.
My question to u experts out there how do i determine whether it is electrical or whether it is the injectors. PLEASE help as i want my truck running
IF YOU have any suggestions please offer if the suggestions are about electrical components please explain carefully as im not really good with a voltmeter or other electrical things.
THANX
slavio is offline   Reply With Quote
Old 11-22-2005, 10:44 AM   #2
chevyguy's Avatar
Try to close off the return line. Might be the fuel pressure regulator, If not then I would do a fuel pressure check.
Old 11-24-2005, 08:16 AM   #3
Problem solved
The two plugs that go into the distributor were not plugged in and they control the pulsing of the injectors
chevy truck drivetrain swap, questions.... beachbum29 Chevy Truck Forum 3 11-23-2005 05:23 AM
1981 P30 Stepvan question about engine swap. darkpony02 Chevy Truck Forum 3 10-30-2005 12:16 AM
LS1 swap jobberone Chevy Truck Forum 3 09-24-2005 06:25 PM
turbo 350 to th400 swap driller1720 Chevy Truck Forum 7 03-02-2005 07:25 AM
88 chevy 350 engine swap???? fix_heli Chevy Truck Forum 2 12-01-2004 03:12 PM
