Old 12-08-2005, 08:43 PM   #1
michelschevy is on a distinguished road
1989 Silverado S2500 Tranny only works after 15 minute warmup???
I'm considering buying a 1989 Silverado with Automatic Tranny.
It wouldn't move in any gear until it warmed up 15 minutes. All gears
worked after that warm up time. The ATF was a bit on the low side but
I don't think that the ATF level was the problem although I have no clue.
Does anyone have any experience with this or have any suggestions?
Thanks!
michelschevy is offline   Reply With Quote
Old 12-08-2005, 08:48 PM   #2
Forgot to add that it is a two wheel drive...
Old 12-08-2005, 08:51 PM   #3
Moderator
Plan on rebuilding the tranny if you do buy it. Depending on how low it was it could be a major issue as well.
mrjohnwayne is online now   Reply With Quote
Old 12-13-2005, 11:48 PM   #4
YngPiggyZ71 is on a distinguished road
Tranny woes!
Sounds like the tranny is full of sludge. Id start with a complete tranny flush and seal check, may an internal seal leak. Depending on the mileage, you might just want to dump the tranny and go with a remanufactured one. Stay away from rebuilts, unless you personally know the builder and trust him and his work or youll be replacing the tranny again in a year or two. Start out small and have a local shop pressure test your tranny and its seals. If its a seal problem then go ahead with the repair and make sure they clean out all of the old fluid and particals.
Keep 'em rollin!!!
YngPiggyZ71 is offline   Reply With Quote
Old 12-30-2005, 11:32 PM   #5
gmtech has a spectacular aura aboutgmtech has a spectacular aura aboutgmtech has a spectacular aura about
seals are probably hard, will need to be rebuilt. Some of the trany additives my the seals more pliable for awhile but its not a long term fix
Old 01-02-2006, 12:09 PM   #6
chevyguy's Avatar
I agree with gmtech. Just leaking back and unable to hold pressure
Old 12-12-2006, 03:41 AM   #7
gmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to behold
Change fluild and add LUCAS transmission addivtive im a true believer of it it fixed my wifes van it was slipping bad cheaper than replacing the trans. Do a search on LUCAS and read what people have written about it this stuff is GREAT.
Old 12-12-2006, 08:52 AM   #8
DonEllis is on a distinguished road
I hope the guy selling it is willing to knock some off the price for a bad tranny
take the money you save to put toward having tranny replaced
can try to have flushed and new filter and keep money in bank till it goes out
Don
DonEllis is offline   Reply With Quote
Old 12-13-2006, 06:20 AM   #9
mod-o-tator
year old!
member map add yourself
