Old 12-18-2005, 06:48 PM   #1
vanhal's Avatar
vanhal is on a distinguished road
running rich
on my brother's 1995 chevy 5.7 with a tbi. it seems to run rich when it is cold out like freezing temp but after running for 5 to 10 min. seems ok
any one know why ??? thank you ............pete
I am gm all the way ....... black 98 Z71 3 door short box 5.7
vanhal is offline   Reply With Quote
Old 12-20-2005, 05:02 PM   #2
check temp sender for the ecu (not the one for the gage) This has a large effect how rich the computer sets the engine. Check engine grounds and ground wires around ecu. Measure the ohms of the sensor at different temperatures to see if is ok. It is a reverse cofficient thermistor which means it will have higher resistance when cold and a lower resistance when it warms up. Bad connections add resistance and make the computer think it is much colder than it actually is so it richens up the mixture. Hope this helps. You will have to check a manual for the values at different temperatures. You can also measure the voltage with it connected up and running. Teflon tape can act as an insulator and screw you up if the sensor does not have a ground wire. I am not familiar with your particlular fuel injection system, just fuel inj systems in general so this is general information not more specific.
99 F250 running boards Gallavantin Ford Truck Forum 1 10-19-2005 11:46 AM
Running from Hurricane!! ladutjr Off-Topic 3 08-30-2005 10:15 PM
daytime running light bigtruckguy GMC Truck Forum 6 03-31-2005 07:47 PM
Running on Empty (The Fresno Bee) trucknews Truck News (headlines) 0 11-07-2004 09:30 AM
OSBI: 11th Truck Stop Murder Victim Identified Investigators Running DNA Tests On Nebraska Truck Driver (ChannelOklahoma) trucknews Truck News (headlines) 0 09-24-2004 03:30 AM
