| Junior Member Join Date: Dec 2005
| 97 Siverado Brakes My brake light is on, brake pedal is real soft, checked the fluid, topped it off, pumped the brakes, pedal still soft, no fluid leaking anywhere that I can see. What's my problem? Master Cylinder? Thanks so much for suggestions, and approximate costs to repair. |
| Sounds like air in the lines, Look at the rear wheel cylinders for evidence of fluid leaking, If you had to top it off then it is leaking somewhere.
| have u ridden ur brakes too hard? like, down a mountain or sumthin.... i know that you should downshift, but alot of times ppl brake too hard, could of lost it doin sumethin like that
| That just causes warped rotors and premature brake wear. Your loss of fluid makes me think you have a leaking wheel cylinder.
| Im with chevyguy if you had to add fluid there is a leak and whel cylinders are common. If you didnt have to add fluid and the pedal is low and soft could be a master cylinder bleeding down internaly. |
| brakes overheat bigtime but i replaced everything | jazzzmonky | Ford Truck Forum | 8 | 11-13-2005 11:55 AM |
| Gravel Truck Loses Brakes; Smashes Into Cars (KGTV TheSanDiegoChannel.com via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 09-21-2005 01:30 PM |
| Investigators find that logging truck had no brakes (New Bern Sun Journal) | trucknews | Truck News (headlines) | 0 | 03-24-2005 11:30 PM |
| Sign Truck Loses Brakes; Crashes Into 'Sinking Ship' Garage In Seattle (KOMO) | trucknews | Truck News (headlines) | 0 | 03-20-2005 07:30 PM |
| Engine brakes spark uproar (The Hawk Eye) | trucknews | Truck News (headlines) | 0 | 11-08-2004 11:30 AM |
