| Junior Member Join Date: Jan 2006
| 2002 Silverado won't start After several years of faultless service -- the only exception was a starting problem due to a wet distributor cap, which was solved by washing and drying -- my "03" (mfd in 02 with a distributor ignition system) will not start. There is a spark at the two cylinders that I tested. Most puzzling is that it will not even hit when starter fluid is applied through the throttle body into the intake manifold. How can I determine if it is ignition or fuel? Thanks, mn indy |
| Outcome found After taking a pressure test that showed pressure of over 60 psi, the ignition system was re-examined. Although some spark was found at the plugs, it was determined to be weak. Upon replacement of the rotor, the Silveraod starting immediatly. Surprise. MN |
| good job, glad you fixed your problem
| Senior Member++ Join Date: Jul 2004 Location: Albany, NY
| Well, glad you got it fixed!
__________________ 2002 Patriot Blue Ram 1500 4x4 in the process of some mods *****Voted Best Truck on HGS***** Silly boys!! Trucks are for girls!!! "Grab Life By The Horns" |
| Senior Member Join Date: Jul 2004 Location: Southern Missouri
| awesome, good to hear another chevy on the road
__________________ http://www.cardomain.com/ride/644045 Trucks are just cars when they grow up!!! If your gunna get a truck....Get a TRUCK!! |
| 2002 Silverado Lift Kit | Kevin Hod | Chevy Truck Forum | 13 | 05-08-2006 12:01 AM |
| truck won't start | waterdog | Chevy Truck Forum | 1 | 12-30-2005 11:10 PM |
| need help with 99 silverado won't start | homebrew13 | Chevy Truck Forum | 1 | 07-28-2005 05:31 PM |
| Ram won't start | 85s10383 | Dodge Truck Forum | 2 | 07-25-2005 08:55 PM |
