| Junior Member Join Date: Dec 2005
| bad vibration after changing u joints and carrier bearing i changed u-joints and had new a new carrier bearing pressed on at a local machine shop, now i have a bad vibration in drive train . i marked the drive shaft befor removing it . this is on chevy 3500 HD.ANY HELP WOULD BE GREAT, THANKS LARRY IN OHIO |
| Maybe you got the driveshaft out of sync? Either that or your u joints arent completely seated into the saddles.
| Senior Member Join Date: Mar 2005 Location: ontario, canada
| u joint better put it apart and take a look at tyhe joint cups one side may be out a bit could give them a rap with a hammer ..lol ......pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 |
