Old 01-18-2006, 10:31 PM   #1
mntman is on a distinguished road
85 silverado fuel pump mystery
I changed out my fuel pump because it was leaking running perfect.I but the new one in and no start.I poured fuel over the carb and it stared,and died.I returned the pump but a new one in it didnt work.I put the old one in it didnt work,it did before.I put the rod up to the cam and put the pump in to be sure it was right and it still didnt work.What ele could be wrong,can the cam or timing chain be bad or the rod?
mntman is offline   Reply With Quote
Old 01-19-2006, 07:29 AM   #2
Your probably not getting the pump in right so that the rod is not working the pump. I'll try to explain how to do it. The fuel pump is on the right front corner of the engine and on the front of the engine facing forward there are 2 bolts or bolt holes that thread in from the front of the engine toward
the fuel pump. If i remember corectly the upper hole of the 2 goes all the way into the fuel pump rod. So with the feul pump removed push the rod back up inside the engine and find a longer bolt to go in that upper hole from the front of the engine and screw it in til it touches and holds the rod up. You dont need to tighten the bolt up just enough to hold the rod up til your able to get the fuel pump in and under the rod. Then remove the long bolt reassembly and then the fuel pump should work since you said it ran before I can't believe anything else went wrong. I hope this helps.
Old 01-19-2006, 08:35 AM   #3
ok
the bolts are even with each other what else could I use to hold up the rod? thanks that helps me picture everything better.
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 02:53 PM
02 Silverado water pump. Kevin Hod Chevy Truck Forum 9 12-07-2005 07:20 PM
dead fuel pump walterv Dodge Truck Forum 8 10-28-2005 07:33 AM
Fuel Pump Problems p_kotenko Dodge Truck Forum 3 07-10-2005 07:45 AM
fuel pump sean Ford Truck Forum 3 10-27-2004 10:37 AM
