Old 01-20-2006, 12:12 PM   #1
Little Grub is on a distinguished road
Exclamation Engine Vibration
I recently installed a manual transmision in my 1989 K1500 pick-up that originally had an automatic, and now a have a very bad vibration in the engine. I bought a new flywheel for that year of truck and a new cluch and pressure plate and throw-out bearing and also a new pilot bushing. The motor is about 5 years old and is a balanced and blueprinted crate motor from Autozone. What are some possible causes?
Little Grub is offline   Reply With Quote
Old 01-20-2006, 01:12 PM   #2
Moostang's Avatar
Was that engine balanced with that flywheel? It could be one of the causes.
MEOW!!
Old 01-20-2006, 10:51 PM   #3
chevyguy's Avatar
Is the vibration noticable with the truck sitting still and the clutch depressed, or just when driving?
Old 01-21-2006, 11:00 AM   #4
You might check with a parts store and see if the harmonic balancers are the same for an automatic and manual transmission, something tells me they are different.
Old 01-27-2006, 06:23 PM   #5
Thumbs up
Thanks guys,
I got thinking about it the other day and thought that the imput shaft may be bent were it rides in the pilot bushing, so I pulled the tranny and went and got a junk-yard five speed and that solved the problem. I sound kinda weird because even with the transmission in gear and the cluch pushed in it still vibrated because the pilot bearing was still spinning around the end of the imput shaft. It now works great and gets better gas milage! Thanks Again.
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 19 10-07-2007 01:46 PM
Service Engine Soon light ralphmorgan GMC Truck Forum 14 01-08-2007 05:39 PM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 10:07 PM
90 C1500 engine problem...HELP!!! Robbman Chevy Truck Forum 9 11-16-2005 09:42 AM
Engine swap ? 72farmtruck Chevy Truck Forum 3 11-10-2005 09:57 PM
