| | #11 |
| as far as that syringe method, you can just buy whats called a pressure pot, and that does the same thing, but it's prolly easier than a syringe. the only problem though is the system has to be reverse-bleedable.....most car systems have valves or something that keep em from bein bled that way
| | #12 |
| Negative johansen^^^^ for the hydraulic system to work it must be able to return fluid to the reservior from the slave cylinder as well as from the reservior to the slave cyl. Otherwide it would just hold constant pressure when you depress the clutch and it would not release. just like brakes. If the fluid couldnt return from where it came from they could only work once.
| | #13 |
| wouldnt that mess someones day up, jump in you truck and depress the clutch and find out that it wont come back out. |
| | #14 |
| bad news. Happened to me in traffic, but it was a manual clutch, and it just engaged and the truck too off, i shut it diwn befire I hit anything thankfully. The cotter pin the kept the linkage together under the dash broke so the pedal went to the floor and the truck just took off.
| | #15 |
| ooo, guess i was wrong, not affriad to admit it
| | #16 |
| We all start somewhere. I am still learning from day to day.
| | #17 | |
__________________ John Wayne 2000 F-350 7.3L Powerstroke 4x4 | |
| | #18 |
| Broken clutch cable. I had to go thru downtown New orleans starting it with the trans in gear when the lights turned green. Fun times
| bleeding brakes | jims | Ford Truck Forum | 3 | 01-20-2006 11:24 AM |
| clutch bleeding | 72'CaminoKid | Ford Truck Forum | 6 | 11-28-2005 10:42 PM |
| clutch in a f-250 | s10owner | Ford Truck Forum | 5 | 03-25-2005 04:00 PM |
