| silicone gasket does anyone know if that silicone gasket stuff can substitute for an O-ring??
| I wouldn't do it, which o-ring are you are trying to sub for?
| its a 3.5" oil system o-ring..... if i use the silicone along with the broken o-ring to try and seal the crack, would that work??
| I am not familiar with that (ford person) put if you use silicon that break is going to be weak point in that ring and if there is a large amount of pressure on the other side of the o ring then it will blow out through the silicon. In my experience o-rings are using in highly pressurized areas, in parts that might move or in areas where you are likely to remove the parts making silicon a pain to constantly clean. The only time I have every seen silicon gasket maker subsituted for a real gasket is for the cork gaskets(like around oil pans and valve covers), which is really what they were make to subsitute (although I personally will use the cork with a thin layer of silicon) It is a hard to find part? I can't imagine it is to pricey.
| Senior Member Join Date: Dec 2005 Location: Texas
| Scottie, Do not use a broken "O"-ring with goo on it. You can go to either www.mscdirect.com or www.mcmastercarr.com and order an "O"-ring for a few bucks. These are industrial supply houses and can have the one you need delivered in a few days. Good luck. |
| Get a new o ring, If its worth fixing, its worth fixing right.
| thanx guys, i appreciate that i didnt make a mistake here... i did end up having to drive the 45 mins to get the o-ring from a chevy distributer, but at least i got it now. i appreciate the help once again guys!
| 45 minutes? that bites, we have one in spittin distance of my house
| yeah, i got a Mopar one like 5 mins from my house... the GM one is right next to Boston so i gotta fight traffic if i wanna get there
| it's nice livin in a small town, traffic aint a problem like in the big cities....
| 76 Chevy 454 - massive oil leak in rear of engine | MrDavidOgle | Chevy Truck Forum | 22 | 06-24-2009 07:03 PM |
