Old 02-15-2006, 01:55 PM   #1
klink70 is on a distinguished road
Carb to TBI engine swap
I'm in the process of rebuilding a carbed engine to swap into my '94 pick-up. They're both 350's. My '94 is a TBI unit. Will a cam for the carbed engine work with the TBI unit? Will the mechanical fuel pump rod lobe on the cam cause any problem or vibrations on the TBI unit since it won't be being used? The engine I'm rebuilding has a 2-piece rear seal, the '94 has a 1-piece. I know I need to use the flex-plate for the 2-piece seal with that respective engine. Will the torque converter from the '94 1-piece unit bolt onto the flex-plate for the 2-piece unit? I know somebody out there has done this type of swap before, so if you could help me out with any info I'd greatly appreciate it.
klink70 is offline   Reply With Quote
Old 02-15-2006, 03:36 PM   #2
chevyguy's Avatar
The only problem you will have is head to intake mounting. the newer heds have a different angle on the center bolt for mounting the intake. The cam if it isnt alot over stock should be fine I would need the specs to be sure. The fuel pump lobe is not an issue. Flexplate isnt an issue either. Go for it.
USMC 92-96 USCG 98 to present
Old 02-16-2006, 07:41 AM   #3
Will the TBI intake work on the carbed engine? Can I modify it ,to make it work? Or can I get an intake with the proper bolt angles that will accept the TBI unit?
Old 02-16-2006, 11:55 AM   #4
chevyguy's Avatar
go to your local machine shop, they have probally done this before, My question is why dont you swap to the newer heads, they flow better than the older heads, If you want a good factory head use the l31 vortec head, i like them alot and they outflow the old 2.02/1.60 heads.
Old 02-17-2006, 09:00 AM   #5
I was pondering that very idea last night while looking at the truck in the shop. I also pondered just redoing the entire '94 engine. However, the old carbed model is a Targetmaster crate unit. It has a four-bolt and a forged steel crank. Would the '94 have the same crank set-up?I haven't yanked that engine yet, as it still runs, but I use the truck sparringly. You say the '94 TBI heads have a better flow rate? That's cool. Would the push rods be the same length between the two engines, or would I need to use the '94s? Would I have to get a cam spec'd for the '94? And, finally, are the cam bearing journal sizes the same from the carbed model to the TBI model?
Old 02-17-2006, 10:54 AM   #6
chevyguy's Avatar
If you have to pull it all down like this, Why not just rebuild the origional. Alot of mixing and matching makes for problems. I would not recommend running a used cam if you can avoid it. Spend the cash and get a beetter product in the end
1990 1500 engine swap 454 to 350 jchcomputers Chevy Truck Forum 2 02-01-2006 07:45 PM
89 - 93 Engine swap lebrowr Chevy Truck Forum 1 01-29-2006 11:17 PM
Engine swap ? 72farmtruck Chevy Truck Forum 3 11-10-2005 09:57 PM
1981 P30 Stepvan question about engine swap. darkpony02 Chevy Truck Forum 3 10-30-2005 12:16 AM
88 chevy 350 engine swap???? fix_heli Chevy Truck Forum 2 12-01-2004 03:12 PM
