Old 03-08-2006, 11:40 AM   #1
92Jag's Avatar
92Jag is on a distinguished road
Question 78' scottsdale wont start
Here is the problem the truck was running fine until just a few day ago when I went to start it and all I got was a click click click click . . . Whats up is the starter bad?
92Jag is offline   Reply With Quote
Old 03-08-2006, 02:25 PM   #2
Moderator
sounds like battery. Check voltage across the posts. should be around 12.5 volts
Old 03-08-2006, 02:50 PM   #3
92BlueZ71's Avatar
92BlueZ71 is on a distinguished road
yeah either your battery is bad or your alternator went out and your battery lost charge the last time you drove it
CHEVROLET
"Friends don't
let friends
drive a Ford"
'92 Ext. Cab Short-Wide Z71
'62 Short-Stepside C10
92BlueZ71 is offline   Reply With Quote
Old 03-08-2006, 11:59 PM   #4
92Jag's Avatar
I forgot to mention that I had a battery charger hooked up and got the same results and the battery was ok. So should I replace the alternator and is there some way to test to see if it's bad before replacing?
Old 03-09-2006, 03:04 AM   #5
project88's Avatar
project88 is on a distinguished road
its the starter, or bad ground connections to the starter. An altenator will not make a vehicle not start, its just the battery wont charge.
project88 is offline   Reply With Quote
Old 03-09-2006, 11:00 AM   #6
chevyguy's Avatar
Try to jump start it, If it starts remove the negative battery cable while its running, If it dies then its not charging, If not then you have a bad connection. Dont just blindly replace parts, diagnosis your problem and replace the bad part.
Old 03-09-2006, 01:55 PM   #7
92Jag's Avatar
Jumping it did not work so that leaves the starter right? Let me know if I should replace it. Thanks.
Old 03-09-2006, 03:14 PM   #8
92BlueZ71's Avatar
yeah like chevyguy said a sure fire way to check your alternator is to pull the ground cable off the battery with the motor runnin and if it stays runnin than you got a good alternator, if it dies your alternator is bad.
CHEVROLET
"Friends don't
let friends
drive a Ford"
Old 03-09-2006, 04:40 PM   #9
Moderator
I would have the starter tested. not hard to remove on those trucks and it is a simple test at any auto parts store.
Old 03-10-2006, 12:03 AM   #10
92Jag's Avatar
I am not able to tell if the alternator is bad or not because I can't start the engine yet but when I get it started I will check it. Can I test the starter my self if so how do I do that? Take it off and connect jumpers to a battery and then to the starer?
truck won't start waterdog Chevy Truck Forum 1 12-30-2005 11:10 PM
1996 Chevy K2500 Won't start ZGM Chevy Truck Forum 3 12-28-2005 03:35 PM
Ram won't start 85s10383 Dodge Truck Forum 2 07-25-2005 08:55 PM
Please help... truck died now wont start jarrod Toyota Truck Forum 8 01-31-2005 09:49 PM
