| Junior Member Join Date: Mar 2006
| s10 won' crank i have a 1998 s10 2.2 . it will turn over. its getting fire and fuel. fuel pressure 45 lbs. check all sensors.will not crank please help .also replaced timming gear. |
| Are you sure you are getting spark? Where did you check the spark, did you check it at the plug?
| re s10 i checked all the plugs |
| No crank?? How about your starter took a big splat |
| | #5 | |
__________________ Friends dont let friends use body lifts USMC 92-96 USCG 98 to present | |
| | #6 | |
__________________ Rock, Paper, Scissors, Lizard, Spock | |
| Full Member Join Date: Mar 2006
| Have you changed the crank shaft sensor? I had an intrepid that did that it would turn over but not start. But we were not getting fire from the coyal pack. we were getting fire all the way to that then nothing and it was the crank shaft sensor |
| Crank sensor would not get fire, Check timing.
| 22R troubles | 390FE | Toyota Truck Forum | 64 | 12-09-2005 06:43 AM |
| 87 Pickup Won't crank | bbmjy8s | Chevy Truck Forum | 2 | 11-20-2005 11:49 PM |
| F150 no oil pressure | pcapozza | Ford Truck Forum | 4 | 03-03-2005 12:55 AM |
