Old 04-11-2006, 05:16 PM   #1
RSailer is on a distinguished road
Need help with hesitation with my 2000 Chevy Silverado
It doesn't happen every time but when shifted in to gear, it drops RPMs and it has to be shifted in to neutral or park to avoid dying.
Engine is a 5.3L, has a K&N cold air filter, has a throttle body spacer, it has new spark plugs and performance spark plug wires.
RSailer is offline   Reply With Quote
Old 04-13-2006, 03:27 PM   #2
i once owned a 5.7 that had the same symptoms and cant for the life of me remember why.
Old 04-13-2006, 09:40 PM   #3
did this start before or after you installed the "performance" stuff. check your codes.
i'd rather be hunting
Old 04-14-2006, 10:20 PM   #4
It has always done it, even before adding the preformance stuff.
Old 04-15-2006, 06:11 PM   #5
check your fuel delivery and for vacum leaks around TBI. either sucking in to much air or not enough fuel.
Old 04-16-2006, 03:16 AM   #6
Do you have a throttle cable or do you have what we call drive by wire (no cable)?
Old 04-27-2006, 01:04 PM   #7
Bart's Avatar
Bart is on a distinguished road
You want to make sure there is no air leaks between you mass air flow sensor and the throttle body. Any unregistered air that gets after the MAS can create driveablity problems. My first guess is you have carbon build up in the throttle body. Clean all the carbon away from the throttle plate and idle air control motor. In my area we see a lot of the GM trucks with tip in hessitations caused by carbon in the throttle body.
Bart is offline   Reply With Quote
Old 05-08-2006, 06:19 PM   #8
Hey Bart thanks for the great advice!!! You were right on. I took off my throttle body, cleaned all the carbon out and there was a ton of it, and also found 2 small air leaks in the air intake. Resealed them and have not had any hesitation.
Thanks again!!!!
2000 Chevy tranny shifting hard tdbp76 Chevy Truck Forum 5 04-22-2007 09:48 PM
2000 Silverado - "Piston Slap" Snowdooer Chevy Truck Forum 20 11-19-2006 10:23 AM
Trans Issue 2000 Silverado 2000Chev Chevy Truck Forum 3 10-04-2005 06:47 PM
QCTimes.Com: Top Jobs: CHEVY '97 SILVERADO 4x4 Z71 Ext Cab w/3rd door (Quad-City Times) trucknews Truck News (headlines) 0 08-03-2005 11:30 AM
QCTimes.Com: Top Jobs: CHEVY '89 Silverado 4x4 Stepside 3/4 Ton (Quad-City Times) trucknews Truck News (headlines) 0 06-29-2005 03:30 AM
