| Junior Member Join Date: Apr 2006 Location: Pa
| 1990 chevy tk stalls Hello, i have a 1990 chevy tk with a 5.7 tbi, and it stalls the moment it is put into gear. Once it starts to warm up at idle and not in gear it will stumble and stall. the fuel pump, filter, lines are all new. the throttle body base gasket is new, all tune up related items such as plugs, wires , cap rotor are allnew. coil is ok, only thing i question is the computor, distributor, any ideas or suggestions |
| Senior Moderator Join Date: Jan 2005
| Sounds exactly like my husband's chevy. He had it back to the dealer, sent emails, etc. It just kept getting worse. He finally traded it in never knowing what the problem was. Sorry I can't be of more help. |
| Check you idle air control motor. It may be sticking on start up. You can also try spraying a little carb cleaner down the passaage way for the IAC while it is running. If you replace it I recommend using one from AcDelco. |
| I would do a resistance check on your temp sensor. Bet it is out of limits. If it only does this after warming up I think that would be more than likely your problem. Idle Air Control would get a light.
| | #5 | |
Don't take me the wrong way we could both be wrong about the cause of the problem. | |
| One more thing I forgot, check the grounds at the thermostat housing. Two common problems with these gounds. Heavy corrosion buildup from coolant leaking from the radiator hose. Or broken or missing gound connections. When the thermostat is changed sometimes the grounds ripped apart at the housing bolt because the nut work break free on the stud. We find a lot of times people don't take the time to repair and assure good connections when re-installing the housing. It can create a lot of intermittent drivability complaints. |
| I can always retrieve a light with an IAC discrep. Just my experience. Not saying your incorrect, as you seem to have alot of info to give here, Just saying i always get a check engine light with a code 35 when i find a bad IAC or related vacuum leak. However they are are easy to check so i recommend going ahead and checking them out.
| Have u checked for vacuum leaks big problem with throttlebody gaskets getting sucked in |
| | #9 | |
unplug your coolant temp sensor before startup and see if it runs any better.Thats what my truck was doing same problems as you are describing and i replaced the coolant temp sensor and booom there it was. | |
| Last Activity: 04-30-2006 11:32 PM i think we might have a winner for oldest thread brought up. consider this, THREAD CLOSED. |
| True Chevy Lovers Help Me Please!!! Y Is Chevy Better Than Ford?! | chevygirl4life | Chevy Truck Forum | 81 | 03-09-2008 11:26 AM |
| Question Chevy vs GMC | Truck_Man | General Truck Forum | 63 | 04-16-2007 09:15 PM |
| 1989 chevy value | 396chevy | Chevy Truck Forum | 6 | 09-27-2005 10:23 PM |
| P/O 1990 Chevrolet Silverado stepside | Volare80 | Chevy Truck Forum | 0 | 03-04-2005 05:59 AM |
| 1990 Chevy Silverado Water Pump | RICK | Chevy Truck Forum | 3 | 02-11-2005 06:20 AM |
