Old 05-01-2006, 03:59 PM   #1
kruszka is on a distinguished road
Help Power steering leak
Ok I have a 85 C 30 that has been looseing powersteering fluid. There is fluid all over the driver side inner fender. I think the leak is coming from this part, but not sure. I have attached a picture of the part. It seems to only really leak when the wheel are turn hard. Could someone please help ID this part and tell me if it is a expensive repair and how hard to repair is it. Is it something a normal guy can do or does a repair shop have to do the work.
The part that leaks is the part in the center of the pic. It has a rubber gasket there that is cracked.
kruszka is offline   Reply With Quote
Old 05-01-2006, 05:34 PM   #2
if you are not sure where it is coming from exactly, get someone to turn the wheel for you while you take a gander under the hood. most of the time, it is the high pressure line that leaks like a busted sieve
Old 05-02-2006, 04:44 AM   #3
it looks like your steering shaft, no fluid there. clean the surrounding area with degreaser and see were the leak is. most likely going to be a worn line near a connection. make sure the steering fluid isn't overfull.
Old 05-02-2006, 03:28 PM   #4
Ok I found where the leak is. It is in the high pressure line that runs from the steer gearbox to the hydro booster. The hose is clamped onto a steel hose and I am not sure how to replace. I ordered a highpressure hose from autozone and hope it is the same thing. How do I replace it? Do I just lossen the nuts at each end of the line and put the new one on. Also Do I bleed it? If so how.
Old 05-04-2006, 02:04 PM   #5
just take a good wrench and take it off. i have never bled that line, just make sure that you finish refilling the pump after you have cranked your engine and filled the lines.
Old 05-04-2006, 02:06 PM   #6
ill tell you a secret about those lines too, if the break is at the end of the line or at the connection, take the hose to a hydrulic shop and have them repair it, i have gotten lines repaired for half the cost of a new line.
Old 05-04-2006, 04:07 PM   #7
to bleed the lines just turn the wheel lock to lock to get all the air out then refill the pump to the correct level.
Old 05-04-2006, 05:22 PM   #8
chevyguy's Avatar
I recommend using a line wrench for removal. They are flared specifically for lines.
Old 05-05-2006, 04:26 AM   #9
^^^^ agreed, you don't want to strip a nut on any kind of hose fitting.
Old 05-05-2006, 10:50 AM   #10
Just want to say thanks. I got the new line on. It was a pain because it was just hard to get too. but it is one and working. The best part is I dont have to keep buying power steering fluid. Thanks again for all the advise
Power steering problems j_legos Chevy Truck Forum 3 03-27-2006 04:42 PM
'01 Silverado - Power Steering Problem zz5t8n Chevy Truck Forum 1 01-15-2006 09:19 AM
Power Steering Problem zz5t8n Introductions 0 01-14-2006 06:43 AM
power steering vanhal Chevy Truck Forum 6 11-28-2005 06:53 PM
Power steering pump shafts keep shearing off AKHD Chevy Truck Forum 1 10-25-2005 11:36 AM
