Old 05-22-2006, 11:16 PM   #1
74CHEVYC20 is on a distinguished road
idle speed
i have a c20 and i just rebuilt a 283 to put in it. my problem is that the engine seems to run fine during idle in park, but when i put the truck into gear the engine drops in rpms and sounds like it wants to die. if i shift it back into park the rpms jump back up to normal. also when i drive it slowly it does alright, but if i mash the gas it hesistates and seems to make a popping sound inside the carb, and sometimes dies. i have messed with the fuel mixture on the carb and i checked all vacuums. im running out of things to check, any ideas would be great. thanks
74CHEVYC20 is offline   Reply With Quote
Old 05-23-2006, 10:45 AM   #2
chevyguy's Avatar
First timing is if it is popping thru the carb. Set the timing correctly. Second why are you messing with the fuel air screws? Are you using a vacuum gauge to tune it? if not then your just guessing . Set the timing and then set the fuel air scres back to the highest vacuum you can get out of it and it will probally run like a top.
USMC 92-96 USCG 98 to present
Old 05-23-2006, 12:22 PM   #3
i know this sounds stupid, but where is the best place to hook up the vacuum gauge and how can i tell if i might have a intake manifold or other leak? i also cant seem to adjust the timing correctly, i am using a timing light. the engine seems to idle too high. what is the best way to get correct timing.
Old 05-23-2006, 04:05 PM   #4
chevyguy's Avatar
Correct timing by turning the distribuitor with the vacuum advance disconnected.Best place to hook up a vacuum gauge is a nonj essential vacuum port. Something that goes to a non essential place with constant vacuum. Adjust idle with idle screws not with fuel/air mix screws.
1987 Silverado 350 TBI Auto., hard start, won't idle 87Silverado Chevy Truck Forum 8 07-08-2007 07:20 PM
3 speed automatic to 5 speed manual help torino Ford Truck Forum 12 02-25-2006 06:17 PM
Speed Channel Truck Stop: Bill Lester (Speed TV) trucknews Truck News (headlines) 0 07-20-2005 01:30 PM
SPEED Channel Continues to be the Exclusive Home of the NASCAR Craftsman Truck Series (Speed TV) trucknews Truck News (headlines) 0 01-25-2005 09:30 PM
ASA Speed Truck Challenge Renewed for 2005 (Speed TV) trucknews Truck News (headlines) 0 12-15-2004 03:30 PM
