Old 06-10-2006, 08:36 AM   #1
msova is on a distinguished road
Chevy Step Van Motor Swap?
Hi all.
I'm looking at a Chevy P-30 Step Van. the 350 needs rebuilt, and I'm considering showing up on site with a motor and doing the swap there (finding a motor will be next!).
First off....would just about any chevy 350 from the same year (82) work fine? I would think any differences would be in the transmission moreso than the motor.
Secondly, anyone ever swap a motor on one of these? Motor comes out the front I assume? Are all bolts accessible from underneath and/or through doghouse in cab?
thanks.
msova is offline   Reply With Quote
Old 06-10-2006, 02:16 PM   #2
Moderator
As long as the motor is set up the same (carb/ throttle body etc..) there should be no problem swapping. Transmission won't be an issue. As for the accesability of the bolts I can't help you there.
Old 06-10-2006, 05:38 PM   #3
chevyguy's Avatar
Yip same block . Just bolt on accessories and go.
Old 06-11-2006, 06:53 AM   #4
Moderator
bradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud of
get ready for some fun. the motor does come out after taking off the front grill and such but it does not just slip out. working on vans are alot more of a headache since you can not just lift the engine out. try and take as much off the top as you can as this will help it come out easier. Also, mind the distributor, it is very easy to beat on the way out. all the bolts that you are required to take off to remove it are accesssible. from doghouse and underneath both. you will find the tranny bolts alot easier to take out than normal i believe.
Question Chevy vs GMC Truck_Man General Truck Forum 63 04-16-2007 10:15 PM
Chevy Luv Itstali25 Chevy Truck Forum 5 06-01-2006 11:32 AM
Current Draw - 1998 Chevy Tahoe bugnutz Chevy Truck Forum 6 05-22-2006 08:42 AM
1989 chevy value 396chevy Chevy Truck Forum 6 09-27-2005 11:23 PM
