| Senior Member Join Date: Jun 2006 Location: Greenwood, Mississippi
| transmission adjustment????? I have a 93 C-20 van with a 4.3 engine, can't tell you what type transmission is in it, the problem I am having is when it shifts between 1st and 2nd, it shifts real hard, no other gear does this, is there an adjustment that can be made to correct this??? many thanks, Frank aka crazyhorse357 |
| How long since the fluid and filter was changed? How many gears, should be a 4l60e transmisssion if it is a 4 speed auto
| reply No idea on the filter and fluid, just bought it about 2 weeks back, it doesn't appear to have been maintained very well. and yes it is an OD tranny, 4 gears Last edited by crazyhorse357; 06-16-2006 at 11:34 PM. Reason: forgot something |
| 4L60E, Time to take it to the transmsiiion specialists. No adjustment you can make on this
| reply Do you know if there is an adjustment that the trans guy can make or will the teans have to be removed???? |
| This is not an adjustment issue. Talk to your local shop and have it diagnosed. Then you will know what needs to be done.
| auto transmission won't shift and rpm& speed guages don't work | gmcer | GMC Truck Forum | 13 | 05-04-2006 08:27 AM |
| transmission swap | cap mowers | Dodge Truck Forum | 1 | 04-12-2006 05:53 PM |
| Transmission fluid?? | Schrodes | Ford Truck Forum | 4 | 12-12-2005 02:52 PM |
| Transmission help | damarr30 | Dodge Truck Forum | 2 | 10-30-2005 12:09 AM |
| Transmission Help Needed | George911 | Ford Truck Forum | 7 | 08-02-2005 11:35 AM |
