Old 07-03-2006, 04:09 PM   #1
csramsey640 is on a distinguished road
2wd to 4wd conversion
Just would like a general idea what is needed to make a 2wd truck 4wd? I am wanting a winter project, and plan to make a 1987 c30 into a k30.
Is the frame the same? Mounting holes there? etc?
I know its a major deal, but I will have both down to the frame and axles only.
Thanks
csramsey640 is offline   Reply With Quote
Old 07-03-2006, 09:29 PM   #2
chevyguy's Avatar
Quite a bit of work , Hows your welding skills?
USMC 92-96 USCG 98 to present
Old 07-04-2006, 09:20 AM   #3
I take it the best route is to cut and weld the front frame section onto the 2wd frame?
I am pretty good at welding, and have some decent years experience with both Mig and Arc welding.
Old 07-04-2006, 12:33 PM   #4
chevyguy's Avatar
cutting and welding the frame should be left to the pros, The frames are heat treated and welding them makes them weak where the heat was introduced. You can fishplate to make the wwleded area stronger, but you only make the weak area larger by adding heat with the welder. It is something that can be done, but I think converting your existing frame would be better bet.
Old 07-04-2006, 03:09 PM   #5
Hayden's Avatar
why not just put your body on the 4x4 frame. Just a thought
Old 07-05-2006, 08:07 PM   #6
yeah, I dont really feel confident welding frame sections on a commercial purpose truck. Around here finding a 4x4 crew cab 73-87 is like pulling teeth, but I can find a k30 reg cab, and a c30 crew cab.
Old 07-05-2006, 11:49 PM   #7
chevyguy's Avatar
Take a close look at the frame of each of them . I think there is quite a bit of difference between the 2wd and the 4wd frame.
95 Chevy Conversion Van Mckheean Truck Classifieds 7 07-08-2006 07:31 PM
Need Infor for 1989 305 to 350 conversion ApplianceGuy Chevy Truck Forum 8 05-31-2006 11:02 AM
97 4.2 v-6 conversion Goatman247 Ford Truck Forum 5 03-17-2006 07:54 AM
4wd conversion 72'CaminoKid 4x4 trucks / off road 12 02-15-2006 03:27 PM
conversion help! alex118 Ford Truck Forum 3 09-15-2005 01:16 PM
