Old 07-04-2006, 09:09 AM   #1
WickedIronhead is on a distinguished road
2 questions
first, im trying to take out my drivers side power window motor on my 1986 Suburban, but i cant figure it out. theres just no room to see anything. i have it unbolted from the door, but i still cant get it it out. anyone know how? will a motor from a 1988 Oldsmobile Delta work? and second, i recently changed my a/c to r-134 from r-12, and charged the system to 45 but its not getting cold. any ideas? Thanx
WickedIronhead is offline   Reply With Quote
Old 07-04-2006, 12:26 PM   #2
to 45?? did you charge to 45 PSI and the low side?? If so then it is not enough. 134 runs around 120 psi or so on the low side. Don't hold me to that exactly but it is alot higer than R-12.
Old 07-04-2006, 12:35 PM   #3
chevyguy's Avatar
no the window motor wont work. It will come out but the window has to be in the up position to allow enough room. Yes your cooling system is low, Did you evacuate it before charging it, If not them dont expect great results.
USMC 92-96 USCG 98 to present
Old 07-04-2006, 07:32 PM   #4
i dont even know what evaguate means.... but it was empty. i bought a kit that converts and recharges r-12 to r-134 and it said that 45 was as high as i should go, any higher would be dangerous. is this incorrect?
Old 07-04-2006, 11:45 PM   #5
chevyguy's Avatar
it means did you evacuate the system, and put a negative pressure on it before charging it or did you do it half heartedly.
Old 07-05-2006, 10:41 AM   #6
for future referance, dont convert to 134a. if you have a 12 system, completely evacuate the system and install 417a. it is a clone for 12 that utilizes the exact same pressures as 12 with the cost of 134a. you will not need to replace anything, e.g. accumulator, orifice tube. it will freeze you out just like 12.
Old 07-05-2006, 01:52 PM   #7
Thats good Info Brad. Never heard of 417a Before.
Several Questions speadphreak Chevy Truck Forum 1 12-27-2005 07:54 PM
Questions, Huge engine havoc1336 Chevy Truck Forum 21 10-02-2005 05:57 PM
Canyon Questions trkman GMC Truck Forum 1 01-16-2005 11:37 AM
Colorado Questions trkman Chevy Truck Forum 0 12-17-2004 12:52 PM
Do Your Homework Before Hiring a Moving Company; Experts at Two Men and a Truck Advise Checking References, Asking Questions (PR Newswire) trucknews Truck News (headlines) 0 07-20-2004 09:30 PM
