Old 07-12-2006, 09:09 PM   #1
teampenner is on a distinguished road
Exclamation replacing AC Compressor
I have a 2001 Chevy 2500 with the 6 liter engine and want to replace the compressor, acumulator and orifice, have never done this recharged the system one time but I need some help in directions to replace these three items and any other helpful advice so I do it correctly.
Thanks Chris
teampenner is offline   Reply With Quote
Old 07-13-2006, 06:37 AM   #2
seems a little early for the year. are you doing a upgrade?
i'd rather be hunting
Old 07-13-2006, 06:59 AM   #3
make positively sure that you put a backup wrench on those accumulator lines as if you just bust them off, you will mess up something that you dont want to change out. same thing on the connections next to your condensor where i believe the orifice tube is located. Also, EVACUATE the system before you put a stitch of refrigerant into the system.
why are you changing these parts out, anyway??
Old 07-13-2006, 07:18 AM   #4
I am replacing these parts because my compressor has locked up on me and dont know whether its just the clutch or the compressor so im changing the compressor to be safe and the warranty says I have replace the accumulator and the orifice also
Old 07-13-2006, 10:30 AM   #5
that is really odd that it has locked up after such a short period. usually a compressor will lock up when it runs low on refrigerant but the low pressure switch that you have is designed to prevent such occurances from happening. if you have already added freon to your system, it would be wise to check for leaks before diving off to far into this. you might be investing in a new low side or high side line (if your lucky).
Old 07-13-2006, 11:17 AM   #6
chevyguy's Avatar
Well your probally gonna have a real hard time getting the freon and such without an IMACA license for work on air conditioning. If you have access then make sure you reclaim the refrigerant before you dump it into the atmosphere. Then after cahnging the components draw a vacuum and see if it holds for 30 min, If so then cahrge it. You will have to know how nuch oil and what type goes in the system and you havve to account for the oil you remove with the compressor and in the freon itself.
USMC 92-96 USCG 98 to present
Old 07-13-2006, 01:39 PM   #7
for 134a, he will not require a liscence. you only need a type 1 for 12 and 22 and other non 400 series freons. a type 2, 3, 4 or universal is needed to purchase all 400 series refrigerants.
ask the parts man how much oil will have to be added to your system. i believe its called PAG 103.
chevy, is there a set time for pulling a vacuum?? i have always went by the pull for 45 and set for 30.
Old 07-13-2006, 02:07 PM   #8
well i just bought a new compressor, acumulator and orifice, planning to change them out maybe tonight after work. will flush the system and add the oil into the compressor. probably will see if I can find someone to charge it after have everything replaced. What are ya'lls thoughts?
Old 07-13-2006, 09:00 PM   #9
Hayden's Avatar
You said there's a warranty. Why not take it in to have it done professionally
Old 07-13-2006, 10:09 PM   #10
02F2504x4's Avatar
02F2504x4 is on a distinguished road
Sounds like a warrenty job to me? I would check into that before you touch anything...
2002 F-250 4x4 CC 7.3L DIESEL
Mods
Edge Evo
Edge Juice W/ Attitude
4 Inch Turbo Back Exhaust Straight Pipe
DIY Tymar Intake
Foil Delete
Recon Light Strip
02F2504x4 is offline   Reply With Quote
replacing a 1999 5.4 motor mach Ford Truck Forum 0 05-05-2006 07:38 AM
replacing lug studs question snowplow GMC Truck Forum 2 02-01-2006 09:16 AM
Sections of I-5 in area need replacing (The Seattle Times) trucknews Truck News (headlines) 0 07-22-2004 03:30 AM
