Old 07-19-2006, 06:06 PM   #1
mikerike is on a distinguished road
Question A C issues
Folks help me out!
AC not working. Fuses good: relay not sure.
Clutch will pull in with direct 12 volts from battery.
System charged a week ago and charge gauge still reads the same, so i doubt there is leak in system.
Any Help would be appreciated.
Thanks,
Diagram and points of checking would be helpful.
mikerike
mikerike is offline   Reply With Quote
Old 07-19-2006, 08:17 PM   #2
72'CaminoKid's Avatar
what kinda vehicle
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 07-20-2006, 07:01 AM   #3
need more information, will the clutch pull in when you turn it on?? is the fan on, what kind of vehicle??
Old 07-20-2006, 04:46 PM   #4
Vehicle is a 1995 GMC 4X4 pickup extended cab
5.7 engine, auto transmission
Clutch does not pull in when started but clutch does work if I supply 12 volts directly.
Old 07-20-2006, 04:49 PM   #5
all i can say is that 've dealt with more GM's than anything else, and the majority of em had a non-working AC system
99 suburban xlt
96 silverado
Old 07-21-2006, 06:50 AM   #6
more than likely it is going to be in the switch, relay, or a fuse. check those and sure you ll find the problem
Old 07-23-2006, 02:54 PM   #7
WickedIronhead is on a distinguished road
i would trace your wires, your relays and the like, sounds like you have a short or a disconnected wire.
WickedIronhead is offline   Reply With Quote
Old 07-23-2006, 04:54 PM   #8
Relay good
How do you check pressure switch
Thanks,
Mikerike
Old 07-23-2006, 09:20 PM   #9
hope this will help you out.
i'd rather be hunting
Old 07-24-2006, 06:46 AM   #10
to check the pressure switch, take the connector loose and using a paper clip or some other kind of jumper, complete the circuit. if it does and didnt before, itll be bad. if there is no change than it should still be working as long as you still have good pressure on your guages.
Power issues? SierraToy Toyota Truck Forum 6 06-16-2006 11:12 AM
93 silverado starting issues WetPaint Chevy Truck Forum 6 04-05-2006 06:49 AM
Driveshaft Issues with '05 Frontier, 4 cyl., 2WD, KC, AT onpoint05 Nissan Truck Forum 1 02-15-2006 06:42 PM
98 k2500 starting issues? stelmadl Chevy Truck Forum 19 11-15-2005 04:39 AM
02 S10 headlight issues 84ranger Chevy Truck Forum 0 08-07-2005 02:51 AM
