Old 07-23-2006, 07:43 PM   #1
autopainter83 is on a distinguished road
1995 S-10 motor hesitates over 1500rpm
Hi my name is chad i own a 1995 s-10 its a 4x4 Center port injection Vortec 4.3 I have been going through fuel pumps like no other i dont know if its because they are napa brand or what? Just today i filled my truck up and went to pull out of the gas station as soon as i got over 2000rpm it started hesitating and boging out? I pulled over shut it off and when i started it back up it ran fine for about 5 min then the same thing happened, everytime i turn it off it will run fine for about 5 min then it starts boging after 200rpm if anybody has any ideas or has seen this problem i would greatly appreciate some feed back thank you. Chad
autopainter83 is offline   Reply With Quote
Old 07-23-2006, 08:16 PM   #2
when you pulled the fuel pump did you check the tank for any sediment or change your fuel filter? when was the last time it had a good tune up, it could also be your plugs or wires.
i'd rather be hunting
Old 07-24-2006, 02:40 PM   #3
1995 s 10 hesistation
Yes i have just done the cap rotor plugs wire fuel filter and the filter on the bottom of the pump, the thing that gets me is that it will run fine for about 5 min then it will start acting up out of the blue? When i shut it off and restart it it seems to run fine.....????
Old 07-24-2006, 05:43 PM   #4
have you had your codes pulled?
Old 07-31-2006, 09:34 AM   #5
4x4s1088 is on a distinguished road
I have a 95 Blazer with the same engine and mine done the same thing here recently and i changed the EGR valve and it runs fine now.
4x4s1088 is offline   Reply With Quote
Old 07-31-2006, 01:33 PM   #6
Larry O'Daniel's Avatar
Larry O'Daniel is on a distinguished road
Have you check the fuel pressure regulator? When it goes bad it will default to an open position thus letting the fuel pressure drop to almost nothing. The fuel will bypass and return to the tank, but the fuel pressure will not be high enough for the motor to run. It is vacumn operated so check your vacumn also. If you have accidentally pulled a hose off and losing vacumn. Hope this helps.
Larry O'Daniel is offline   Reply With Quote
1995 Silverado ignition timing Mark Chevy Truck Forum 4 09-14-2008 04:12 PM
1995 K1500 light throttle mis Cam Chevy Truck Forum 9 09-28-2006 09:18 PM
1995 K2500 ABS problem shepard Chevy Truck Forum 1 06-14-2006 02:04 PM
1995 Dodge Ram 2500 ROLLOVER ACCIDENT! myhorsemyrules Introductions 2 04-28-2006 07:17 PM
1995 gmc ''sputtering'' cletus GMC Truck Forum 2 03-07-2005 11:05 PM
