| Junior Member Join Date: Jul 2006
| 1995 chev kv 1500 4x4 |
| sounds like a bad actuator on the transfer case.
| its not the actuator i changed it and i notice too my oil gage jumps could it be a short somewhere. |
| is it in both high and low or just one. is it electronic or manual, i'm thinking electronic. have you tried engaging it in neutral.
| its a shifter on the floor and no havent tried it in neutral first time i own one. |
| sorry for the problem and its as soon as i shift it to 4x4 no matter were |
| my 4 high will not engage unless i am at an almost complete stop and has to be in neutral for 4 low.
| The most common cause of a blown fuse on these that i have come accross is the actuator on the front drive axle shorted unless it has had an updated actuator and wiring harness installed then it cause be where the new wiring harness has been attached usualy above the transfer case which could be rubbing on you manual linkage |
| 1995 K1500 light throttle mis | Cam | Chevy Truck Forum | 9 | 09-28-2006 09:18 PM |
| 1995 S-10 motor hesitates over 1500rpm | autopainter83 | Chevy Truck Forum | 5 | 07-31-2006 01:33 PM |
| 1995 K2500 ABS problem | shepard | Chevy Truck Forum | 1 | 06-14-2006 02:04 PM |
| 98 Chev. 1500 Silverado Ext Cab | ghbeuker | Chevy Truck Forum | 1 | 04-06-2006 08:47 PM |
| New Dodge Ram 1500 First Pickup Truck to Offer MDS (Stoney Creek News) | trucknews | Truck News (headlines) | 0 | 09-23-2005 07:30 AM |
