| A/C Compressor Installation help!!!??? I need to know how much pressure should be run in a 134a system......we have the gauges but we are unsure of how much pressure to charge to. |
| Full Member Join Date: Jul 2006 Location: Texas
| i've been told anywhere between 45-70 depending on humidity which idk if that is a bogus story or what but i think 60 would be pretty good, could be way off but i had 55 in mine and it wasnt too bad but i think i got about 60 or so in it now feels pretty good.
__________________ CHEVROLET "Friend's Don't Let Friends Drive" FORD 1962 Short Step-Side Chevy C10 1996 Ext Cab Chevy Silverado 1500 |
| You need to charge to the proper lbs per the label because with the r134a the pressures read the same with 1/2 lb in it or 2 lbs. The temp and humidity have a big effect on the pressures anywhere from 30-55 or so on low side and 150-300 or so high side. Has to be charged to proper amount. |
