Old 08-30-2006, 05:35 AM   #1
claytonfrnk's Avatar
claytonfrnk is on a distinguished road
Head Light Trouble
I am having headlight issues. I know its wiring because only one headlight works. I have the four headlight system on my 85 silverado and the lower headlight on the driver side is the only headlight that works. I have switched the headlights all around and no matter what only that headlight works. When i turn the right blinker on the blinker blinks but is real dull, also the front passenger side headlight blinks with the blinker but is reall dull. Is there a factory headlight harness replacement somewhere out there or no. I have traced all the wires and all the grounds under the hood. They all seem to be in tact. Does anybody have any suggestions?
claytonfrnk is offline   Reply With Quote
Old 08-30-2006, 05:53 AM   #2
mod-o-tator
my 89 blazer did this on the passanger side as well. i tore the whole wire harness down and the test light showed power all the way up to the headlight plugs. i actully got it to work for a week when i thumped the light with my nuckels. anyways, i finely got it to work by cleaning everything with a small wire brush and useing some of that light bulb goop.
member map add yourself
alldatadiy
Old 08-30-2006, 07:17 AM   #3
I will give that a try. wont be tonight though. Ernesto might hit us. The wife would be mad if i was messing with headlights in a tropical storm
Old 08-30-2006, 11:52 AM   #4
Moderator
the way its lookin, you might have a pretty good turnout with Ernesto. good luck to you with the storm and the truck.
that light bulb junk that mud is talking about is some good stuff. ill vouch for it.
Old 08-31-2006, 06:38 PM   #5
grounds and connections can look good and be bad. time to break out the voltmeter. If you have 12v at the headlights you have a bad ground return. If you don't have 12v start measureing from the switch to the lights.
Old 09-02-2006, 01:27 AM   #6
64longstep's Avatar
64longstep is on a distinguished road
what wojeepster said, and clean all of your conations,then use dielecteic grease on the conaters.
64longstep is offline   Reply With Quote
Service Engine Soon light ralphmorgan GMC Truck Forum 14 01-08-2007 05:39 PM
brake light problem ramdodge Dodge Truck Forum 5 09-18-2006 07:05 PM
Engine and overdrive light chief Ford Truck Forum 2 03-30-2006 07:27 PM
Check Engine light and overdrive light on chief Introductions 0 02-05-2006 08:12 AM
22R troubles 390FE Toyota Truck Forum 64 12-09-2005 06:43 AM
