Old 08-31-2006, 09:39 AM   #1
1988MonsterChev is on a distinguished road
Chevy Cranking Issues
I've got an old 88 with a 350. When it's warm it does not like to crank. I just put a new starter in and the problem was solved for a couple of hours but it has reoccured. Can anyone lend an informational hand towards my problem? It would be much appreciated!
Thanks
Thanks for the help guys! I've ruled out that the motor requires a heavier CA as a possibility. I have replaced all the wiring to and from the starter. But like every 350 and 305 I've seen the starter is quite close to the exhaust manifold.
Thanks for all the help guys... The truck is running great with no complaints again!
1988MonsterChev is offline   Reply With Quote
Old 08-31-2006, 10:07 AM   #2
chevyguy's Avatar
Do you have headers? Does it happen only when the motor is hot, or all the time? Is the exhaust close to the starter? Check all your wire connections and remove and clean them and reinstall them. A bad connection is suspect, but could be heat killing the starter
Old 08-31-2006, 06:32 PM   #3
Put a voltmeter on the postive cable, red on battery + ,black on starter+ crank engine and take reading. Should be .8v or less. Now do the same thing on the negative side black on battery - red on starter ground. Crank engine take reading should be .5v or less. If you are getting a couple of volts or more that cable, connection, etc is bad fix and replace. This is called voltage drop testing. The beauty of it is that you do not have to take anything apart and it tells you where the problem is. Battery cables and connections can look good but be no good. Measureing the voltage drop will tell you where the problem is.
Old 09-02-2006, 01:34 AM   #4
64longstep's Avatar
64longstep is on a distinguished road
it sounds like you need to clean all of the conatins and replace your battery cables.
64longstep is offline   Reply With Quote
Old 09-06-2006, 01:37 PM   #5
Larry O'Daniel's Avatar
Larry O'Daniel is on a distinguished road
Does the negative on the battery go to the motor or the frame? Is there a ground cable from motor to frame? Is the timing correct and not advanced?
Larry O'Daniel is offline   Reply With Quote
Question Chevy vs GMC Truck_Man General Truck Forum 63 04-16-2007 10:15 PM
Chevy Luv Itstali25 Chevy Truck Forum 5 06-01-2006 11:32 AM
Current Draw - 1998 Chevy Tahoe bugnutz Chevy Truck Forum 6 05-22-2006 08:42 AM
1989 chevy value 396chevy Chevy Truck Forum 6 09-27-2005 11:23 PM
