| Junior Member Join Date: Sep 2006
| oil in radiator??? i was working on my new sub box when i went to help someone push there can into a trailer. when i was walking back i saw a line of coolent down my drive way. i look in the radiator and there is oil in it......or there is something else that is black in it.....what does this mean? cracked block or head? |
| Probably a bad radiator. My brothers 96 chevy went through 2 radiators. The core for the transmission fluid busted and would dump tranny fluid into the coolant.
| so i need a radiator and the cooling thing for the tranny and im set? |
| Senior Member Join Date: Jan 2006 Location: Cali
| Yea i seen the same thing today I just pulled out a radiator out a 02 vw passet and i seen this black/grey fluid kinda looked like oil i was like wtf??? lol
__________________ 2002 F-250 4x4 CC 7.3L DIESEL Mods Edge Evo Edge Juice W/ Attitude 4 Inch Turbo Back Exhaust Straight Pipe DIY Tymar Intake Foil Delete Recon Light Strip |
| do i need to do a tranny flush also? and a coolent flush? |
| Senior Member Join Date: Jul 2006 Location: Tulsa, stationed at Ft. Sill, OK
| The "cooling thng for the trans" should be inside the radiator, not a seperate item. I would flush both. Water in the trans will do more harm so it is more important. Flush the radiator/motor after you get it together so you are sure you get all the old oil out. |
| Is this a 2.8 or 4.3 engine? I had oil in my radiator and it turned out to be a cracked engine block. I know, that is not logical, but check around and you may be able confirm this. I had to replace the engine becaus of it. Seems there is a weak spot in the casting where the oil pressure is higher than the water pressure, thus the oil in water when it cracks. Hope this might help. |
| Black makes me think it is probally oil. You need to try to verify what type of contamination you have in the radiator. Check the oil for a flothy milky substance. Check the transmission fluid for the same. if you find it in either then that will help narrow it down. May need to drain and remove the radiatro and have it tested at your local radiatior shop. No sense in replacing good parts. Try to identify wher the problem is. If it is milky oil, You got big problems, If its in the transmission, New radiator.
| Full Member Join Date: Sep 2006
| could be several different things . finding out where the oil came from will be a big help. Blown head gasket could be the problem. Check for bubbles in the radiator fill neck while engine is running at operating temp. |
| i checked the oil in the tranny and in the engine. there was nothing in eather. but the tranny oil was a little runny tho. |
| radiator | fatboi | Chevy Truck Forum | 7 | 09-15-2006 07:20 PM |
| Useing/burning Radiator Fluid | bajaboy | Chevy Truck Forum | 25 | 06-15-2006 08:45 PM |
| 96' 4.3L silverado | 72'CaminoKid | Chevy Truck Forum | 10 | 04-28-2006 06:41 PM |
| Have a problem with bugs sticking to your radiator? | bubbas91lariat | Ford Truck Forum | 4 | 01-03-2006 12:49 PM |
| 2000 GMC Sonoma | Vengeful1 | GMC Truck Forum | 11 | 11-07-2005 08:17 AM |
