Old 09-21-2006, 07:56 PM   #1
Jonc is on a distinguished road
93 Chevy 454 no fire or fuel
I have a 93 chevy 454, 7.4, HD3500 gas 1 Ton that started missing and the last 20 miles to home had to run the excelerator on the floor to acheive 55 miles per Hour. Finally made it home and the pickup stopped running and will not spray fuel or fire. The fuel pump does pressure up and cut off. No fire at all at plugs. Does anyone have any ideals on what it might be. Thanks
Jonc is offline   Reply With Quote
Old 09-21-2006, 08:55 PM   #2
start at the plugs and work your way backwards. if no fire at the plug, see if the coil is firing. if it is, look at the rotor under the distributor. the dizzy might have a crack in it also. if the coil is not firing, it could be a bad coil or that the points in the dizzy need to be replaced or adjusted. dwell meter will take care of that. make sure that you are getting power to your coil from the ignition. turn the key to on position and test for 12v at the positive post. if no power, problem with ignition. and thats ignition 101.
if i remember right, they didnt start using SFI til 95 or 96 so that would put you with TBI. if they are not spraying, i would check the power supply to the fuel injectors. since you are having power problems now, i have to wonder if you have some shorted out wires or bad fuses. i would look into that before you go diving into all that other garbage i have already talked about.
Old 09-21-2006, 11:59 PM   #3
chevyguy's Avatar
Hey brad it a 93, No point to adjust.
USMC 92-96 USCG 98 to present
Old 09-22-2006, 06:50 AM   #4
sorry, skipped over that part. knew i was forgetting something.
Old 09-22-2006, 01:53 PM   #5
Ok This what I done to it. Replaced plug wires, Dist.Cap, rotor, coil, little module located inside dist. thats bolted below the rotor on back side of distributor and fuel relay. Pick up cranked up run smooth, drove it for about 20 minutes and is doing the same exact thing again. Got it back home by putting excelerator all the way to the floor. Turned the motor off when I got home tried to crank it 30 minutes later with no luck. Checked it over and it is not getting fire to the plugs or spraying fuel. Exact same thing as before. Does anyone know if it could be the computer. Thanks
Old 09-25-2006, 08:44 AM   #6
gmcman is on a distinguished road
what no codes
gmcman is offline   Reply With Quote
Old 10-05-2006, 11:54 AM   #7
mr. goodwrench is on a distinguished road
hey try replacing you ignition module the module on your distibutor under the rotor if it goes out you lose spark and fuel. i know you replaced it but did you but the grease that ocomes with it between the module and the distributor. if not it will over heat and fail quickly, like after a 30 minute test drive. hope I helped and good luck
mr. goodwrench is offline   Reply With Quote
Old 10-11-2006, 09:55 AM   #8
cookcs is on a distinguished road
How about changing the fuel filter.
cookcs is offline   Reply With Quote
2001 chevy 2500 Fuel gauge teampenner Chevy Truck Forum 10 08-15-2006 03:08 PM
Contaminated fuel system Phil R Chevy Truck Forum 2 07-23-2006 01:00 PM
Fuel Pump will not turn on? cab41610 Chevy Truck Forum 7 07-17-2006 08:33 PM
98 Chevy 1500 W/T Bigfoot Chevy Truck Forum 2 02-18-2006 05:30 AM
chevy s10 fuel injector problem... rrodriguez190 Chevy Truck Forum 8 10-30-2005 12:23 AM
