| Junior Member Join Date: Sep 2006
| chevy silverado 2500 hd fuse keeps blowing the fuse for the radio,instrument cluster keeps blowing.i have tried unplugling the fuse for both on the little fuse box on the inside of the truck,with brief success. |
| probably shorting somewhere. when it shorts, youll get a voltage spike that will lead up to a blown fuse. check your wires between the fuse panel and the each failing component. since you are having probs with those 2 fuses, the 2 wires might be arcing together. |
| Full Member Join Date: Sep 2006 Location: St. Louis, MO
| are you useing you're cig out lets. If so don't use them and see if it stops blowing. There are some accesories that you can plug into it that will blow out that fuse |
| i would check your cig. outlet. it could have something in there that hits the right spot when you hit a bump or something. if not that then i would check you wires.
| thank you ..will try |
| Chevy Silverado 3/4 Ton | AdmnPower | Chevy Truck Forum | 6 | 12-03-2006 09:36 PM |
| 2001 chevy 2500 Fuel gauge | teampenner | Chevy Truck Forum | 10 | 08-15-2006 03:08 PM |
| 1997 Chevy Silverado 2500 Turbo Diesel | Big Diesel | Chevy Truck Forum | 2 | 11-10-2005 11:25 AM |
| Anyone know what an 87 Chevy 2500 is worth? | 84ranger | Chevy Truck Forum | 4 | 09-22-2005 02:58 PM |
| QCTimes.Com: Top Jobs: CHEVY '89 Silverado 4x4 Stepside 3/4 Ton (Quad-City Times) | trucknews | Truck News (headlines) | 0 | 06-29-2005 03:30 AM |
